Classic Audi » Technical » Technical Info » Clutch Cable - Part Number?
Old 23-07-08, 09:44 PM   #1
Sie!
Default Clutch Cable - Part Number?
Hi everyone,
Just windering if anyone would happen to know off-hand, or know of a way I could find a part-number for my 1985 Audi 80 GL (With a 1.8 DS)'s clutch cable?
I have seen lots of them on eBay, that are genuine, original parts, but there are loads of different part numbers.
Many thanks in advance,
Sie!
Ps. I remember someone once posting a link to an Audi technical resource, part-nuber search site thingy, I went on it and really couldnt work out what I needed, confused me more!
Old 23-07-08, 09:51 PM   #2
phone your local dealer and ask for the part number
Old 24-07-08, 12:41 PM   #3
Sie!
Tried that already, Audi couldnt give me a part number, or so they said.
Just gonna try GSF now.
Sie!
Old 24-07-08, 02:56 PM   #4
Sie!
Ah well, GSF gave me a part number, but cant supply me with the part!
Any other ideas where I can find a:- 811721335P ?
eBay no use either......!
Sie!
Old 24-07-08, 03:14 PM   #5
Try Pete Reeves on 07976832676 or vag parts http://www.vagparts.com/
Old 27-07-08, 07:18 PM   #6
Jim Haseltine
Originally Posted by Simon A. Baskerville View Post
811721335P
According to my parts list, that's for a LHD car.
A RHD 1.8 is listed as 812 721 335 AF.
Jim Haseltine is offline   Reply With Quote
Old 28-07-08, 03:33 PM   #7
Sie!
Jim.... Thank You!
You helped me no end there - I have managed to fine one and order it, an original part, and quite cheap too!
Many thanks again,
Sie!
Old 28-07-08, 11:12 PM   #8
BigT80
Just for info: I've found that pre/post face-lift cars have slightly different cables, they'll both fit, but adjuster is in different place & using the wrong one can stress the cable & make operation even heavier (When I need a knee replacement, I'm gonna claim on Audi ;-) - should have made them all hydraulic, not just 5cyls & q's). Pity I did not see your post earlier: I've got about half-a-dozen knocking about. They should be around £20+VAT from GSF or ECP's. Cheers.
Coupe quattro kv alternator or part number Shaun1706 Parts Wanted 7 08-01-10 10:13 PM
A4 ignition switch part number 20vcqdriver Technical Info 9 31-08-09 09:30 PM
Clutch cable Audi Derek Transmission 0 26-07-09 06:50 PM
Part number for audi 100 wheel bearing? Scarlet Technical Info 14 28-03-09 03:07 PM
part number for fuel pump relay Fitzy Technical Info 2 27-03-09 02:50 PM
