Members: 43,012 | Total Threads: 40,083 | Total Posts: 471,016 Currently Active Users: 1844 (2 members and 1842 guests) Welcome to our newest member, Mauricegople |
Right, I'll be hopefully getting a 90q soon, and I want to put a 7a 20v in it (can't affort a 20vt just yet).
Are the engine mounts the same between Typ89's and 85's? Will the 85 box bolt up to a 7a? Would I be right in thinking the 7a is essentially the same as the 6a with an extra cylinder? What spark/fuel management do they use? Would whatever system it uses control the spark independently if I were to go carb? If not is there any kind of dead basic spark management off another 5 pot I can use (I'd rather not use megajolt or similar, simpler the better)? Ta! |
Cq20v on here has done it,then went 20vt in type85
I'll go find some threads then
One more question, Typ85 90q box on a 7a from a FWD 80/Coupe? |
Bump, can't find anything useful on this? Anyone?
Yes the typ 85 box will bolt to the 7a but you will need a UR WR flywheel and clutch and a spigot bearing for the back of the crank. Not sure on the 6a question I would not think so. I think it is hitachi No you would need to run VEMS, 034, motec etc Not that I can think of. HTH |
Brilliant, thanks!
So will the 7a engine and box mate up to the 85 prop? I can imagine sourcing quattro bits won't be easy or cheap... What about front driveshafts? Not essential since I plan on converting to RWD until I can afford big power ![]() |
And how are u going to achieve this - center diff mod with welding equipment or simply removing front driveshafts and hoping that centre diff lock will work infinitely?
Weld up the center diff and bin the front shafts
