Members: 19,821 | Total Threads: 40,093 | Total Posts: 471,110 Currently Active Users: 12473 (1 members and 12472 guests) Welcome to our newest member, Jamescoexy |
Unused set of Magnecore KV85 HT leads for Audi 80 8v. Listed to fit 91-96 models with ABT engine. Please note that this are for the M4 pin fitting on distributor. Early models may not have these.
Please satisfy yourself that they are suitable for your vehicle. £35 delivered within UK. |
This might help identify the correct cap. As you can see it has threaded 4mm pins.
As this cap is also surplus to requirements, I can through it in to sweeten the deal. It is also new and unused. |
Hmmm I'd have theese but i have the abk engine. Aand Im sure the abk uses slightly longer leads.
Can anyone confirm this. |
I have measured the leads as best I can. The measurements are the total length from end of spark plug cap to distributor terminal connection:
No 1: 340mm No 2: 420mm No 3: 500mm No 4: 580mm Coil lead is 350mm from centre of angle coil connection to distributor terminal. The distributor terminals are straight not angled. Also the width of the wire may mean that you cannot use the original guide tube. There are three wire seperators included which presumably are intended to be used instead! |
cheers i'll have a measure up tommorow.
