Classic Audi » Technical » Mech/Tech » Electrical problems » Drivers side electric window GT5 Coupe 1984
Old 22-05-10, 11:09 PM   #1
Dablad75
Dablad75's Avatar
Default Drivers side electric window GT5 Coupe 1984
Hi all, this is my first "help"! question.
My drivers side electric window has stopped working, only just bought the car but when I first got it it was quite slow and noisy, now it doest move at all. When I press the switch I think I can hear a noise as if it's trying and also the voltmeter drops a tiny bit - does this rule out a fuse? any advice would be gladly appreciated. Cheers, Dave
Dablad75 is offline   Reply With Quote
Old 22-05-10, 11:12 PM   #2
Could be the actual switch?
Swop over switches(right,left),if it work it,s the switch.
KARL.
Old 23-05-10, 02:48 AM   #3
5potnoodle
OCD member
5potnoodle's Avatar
Sounds like the cable in the mech has snapped through old age/rust.
Current:
99 Subaru Forester S-Turbo Auto - interesting... but it's not a quattro
91 Reliant Scimitar SST 1400 - no.39 of 42... something for the weekend
Previous:
Two consecutive 1989 Audi 200 Quattro Turbo Avant, 1B
1990 Audi 100 SE Avant, NF
1986 Audi 100 CD Avant, KU
1987 VW Passat GL5E Estate, JS
"Honorary" triple member of the 200,000+ Club
Audi 200 in the UK (legacy website)
Classic Audi member no: 258
5potnoodle is offline   Reply With Quote
Old 23-05-10, 05:01 AM   #4
impsdude
impsdude's Avatar
I have the same problem on my 83' coupe. Any hel would be good.
impsdude is offline   Reply With Quote
Old 23-05-10, 09:47 AM   #5
Dablad75
Dablad75's Avatar
Right, took door panel off and the cable is still in place - does this rule out a snapped cable or is there more than one? I can definitely hear a click sound coming from somewhere when I press the switch and the volmeter drops, is there a relay relating to the windows anywhere? I popped the switches out but dont have a soldering iron so havent tried swapping them over. If I do need a new motor and cables is it an easy job? and any suggestions where to get them from? - thanks!!!
Old 23-05-10, 10:06 AM   #6
20vcqdriver
20vcqdriver's Avatar
The early electric window motors were prone to sticking as the motor brushes wore down. If the door panel is off try and get a multimeter onto the motor terminals and see if you get 12v (or therabouts) when you operate the switch. If you do, the motor needs a service/replacement. Can be repaired if you know where to get brushes and commutator has not worn down too much...
Old 23-05-10, 01:21 PM   #7
paulcunningham
paulcunningham's Avatar
It sounds like the cable has chewed up, i managed to swap over the cable and motor only from an 80. Slider rails was different. I have since heard that there are a few companies about that will replace the cables.
When it happend to me (on the way back from collecting the car in Hampshire, rainy day) it was half open all the way back. Did keep me awake though.
paulcunningham is offline   Reply With Quote
Old 23-05-10, 02:06 PM   #8
this is a well known problem for which there can be many different solutions.
When my drivers side stopped working the fault was traced to the connector block at the switch end. It seems there was a significant voltage drop across the connector which made the window move slowly. The connecort blocks were remove and repalced with spade connectors. Put back together and hey presto, window works fine. Could be worth checking and certainly could be easier and cheaper than taking the whole window mechanism out. All for the price of a set of connectors from Halfords
