Members: 19,821 | Total Threads: 40,098 | Total Posts: 471,152 Currently Active Users: 10045 (0 members and 10045 guests) Welcome to our newest member, BuddyInons |
Got a small issue people,
since i bought the 100, the rev counter has only ever worked on 2 occasions.. Also, the clock does not seem to have a permanent power feed to it. Ignition turns off, clock display goes off, ignition back on, the clock comes back on at exactly the same time it went off. Im thinking permanent live issue. Are the 2 problems linked? How on earth can I get the clocks out to see? theres a mass of very well put together plastic! Also my temp gauge never seems to go very high, only once have I seen it his halfway, is this normal? Cheers Matt |
#2 | |
read these million words..
http://www.sjmautotechnik.com/troubl...nstrument.html Quote:
dodgy connectors at the temp sensor on mine and instrument panel solders were to blame. if you do these and its still not getting up to temp..then could be the pressure escaping out of the water system...(leak)..... ![]() which i also recently experienced... ![]() |
HELLLOOOO Missfire!
bloody hell that is a million words!! and you make a good point about the 'stateside' comment ![]() |
