Members: 19,823 | Total Threads: 40,093 | Total Posts: 471,115 Currently Active Users: 2143 (0 members and 2143 guests) Welcome to our newest member, BuddyInons |
hi guys, my recently acquired, Coupe GT has got a hunting idle when cold
when warm it idles perfectly, and the car drives perfectly when hot and cold I have check the idle stabiliser for Current going into the unit and there is power going to it, however if i unplug the unit (whilst its hunting) nothing changes. is this a sign of a nackered idle unit or does this unit only work at certain times the car is also running quite rich many thanks jim |
#2 | |
i take it this is the one with the green plug on the IM? should i disconnect it when running/hot/cold?
Yes, the cold start injector is up on the inlet manifold, we run both of ours disconnected all year, they're ideal for very cold starting, but with the uk's temperate climate they can, even when working normally, flood the engine when cold. If the injector is partially blocked and firing longer than required, it could make the old girl hunt. BUT, it could quite easily be something else.
Anyway of over hauling the cold start injector?So expensive,for what they are.
thanks for your help isimmo, much appreciated, will keep you updated!
i tried the 6th injector this morning . And no difference i am afraid.
Okay-doakes, back to stage one then...
German Language Assistant
Does this engine have an idle stablisation valve? Common problem on 1.8 Golf GTI engines. The ISV can get dirty and cause this hunting. ISVs can be cleaned but not too expensive to replace and quite an easy job.
1976 Audi 80 L - Sleeping 1977 Audi 80 GLS - W.I.P 1991 Golf Mk2 VR6 Supercharged 2003 Audi A6 Allroad - Daily |
yes it does mate, will try to source one i think as im sure it should cut out if you unplug it?
