Classic Audi » Technical » Mech/Tech » Wheels & Tyres » 16" x8j, ET 24.. on a 10v 200?
Old 18-05-08, 08:37 PM   #1
wedgedout
Default 16" x8j, ET 24.. on a 10v 200?
Seeings as I've got a lovely set of 5 spoke speedline split rims..
What's the chances of em fitting?
Will I have to "massage" the steel work, or am I looking at arch extentions?
They're going on... just a question of how
I also plan to lower the car, probably on some custom coilovers. (so low...)
wedgedout is offline   Reply With Quote
Old 18-05-08, 08:44 PM   #2
wedgedout
Old 18-05-08, 09:24 PM   #3
Octanejunkie
Octanejunkie's Avatar
Providing the stud pattern and bore size is the same...
You shouldn't have to modify the arches with the cars standard suspension.
if you slam it to the deck, it may be another matter. You might be able to get tyres with a 45 or 40 profile which could help with clearance.
Old 18-05-08, 09:45 PM   #4
wedgedout
they're apparently from an audi, deffo 5x112 with the larger centerbore, so will go on there physically.
I do want to slam the car down fairly low, but it sounds like I can just massage the arches if they'll fit on a standard car.
Old 18-05-08, 10:16 PM   #5
could you come back a bit with the photo please... even though you state what car it is... I just cannot for the life of me work out those body panels!! that panel gap coming up over the wheel has got me tottaly stumped
cheers
Old 19-05-08, 03:39 AM   #6
AlanB
AlanB's Avatar
Hi Q-K,
looks like a VW bay window van to me?
Hi Wedgedout,
The 200s have loads of clearance at the front, but the rears are tight.
The clearances on the rear are different for 2WD and quattro; the rear track is wider on the quattro, but the bodywork is the same.
I have had to run extra negative camber on the rear to allow clearance for even the Fuchs 7x15s, and have eventually gone back to the standard 6s, to get the geometry back to where it should be.
Other owners seem to have had less problems than me, so either the cars vary, or I am too fussy.........
AlanB
AlanB is offline   Reply With Quote
Old 19-05-08, 07:40 AM   #7
wedgedout
cheers
The chap I traded them with had a late Bay Window van, that's what they're fitted on at the moment
Old 19-05-08, 07:41 AM   #8
wedgedout
Originally Posted by AlanB View Post
Hi Q-K,
Hi Wedgedout,
AlanB
I don't mind doing some "work" to the rear arches if I have to
Old 19-05-08, 03:08 PM   #9
AlanB
AlanB's Avatar
Hi Wedgedout,
I think you will need to do something.......
A set of the 20V arches would help, but I don't know where to find those, only the fronts.
AlanB
Old 21-05-08, 09:33 AM   #10
burny
everything is said.
without reworking the rear arches, maximum is 7,5" ET35.. and sometimes depending on the make of tyre, you have to pull a little bit on the arches.
I had the case when I fitted the V8 wheels on my 200, with Bridgestone RE720 tyres (205/60/15).
A friend of mine has also put the V8 wheels, but for him it was ok, the tyres were in the same size, but not from Bridgestone
you could find some 200 20V front wings here :
http://sites.internet.lu/folders/cus...craft/main.htm
burny is offline   Reply With Quote
Inquiry into a remake of the "holy grail" wheels Cornholio General Chat 6 23-09-09 07:33 PM
