Classic Audi » Technical » Technical Info » Under bonnet pics of Coupe quattro
Old 09-04-08, 07:23 PM   #1
Default Under bonnet pics of Coupe quattro
I've had several discussions recently about the layout of the KV under-bonnet pipework...
These pics are from ours, a (as far as I'm aware) standard layout 86 KV....
General view
Air flow meter area
Cold start area
Distributor
Battery to block view
Under the Air flow meter area
Hope this helps any interested parties...
Ian
Old 09-04-08, 07:47 PM   #2
You want to disconnect the fuel cut off valve on the rear of the airbox ( thick brown wire ), you already have, then your exhaust will come into it's own.
Old 09-04-08, 07:56 PM   #3
Nope, all's still connected as normal... What, pray, goes on after disconnection?
Old 09-04-08, 09:13 PM   #4
The fuel cut off valve works on negative pressure. When you lift the throttle the butterflies close in the throttle body causing the tick over switch to close to tell the car not to fuel. The resulting pressure build up in the airbox causes the fuel cut off switch to activate, effectively cutting off the fuel. Now, disconnect it and it keeps on fueling even when you lift off. Result.....some spectacular pops and bangs from the unburnt fuel going down the , now, already larger exhaust system. Sounds really good. Uses more fuel but sounds good.
Old 09-04-08, 09:33 PM   #5
I'll give it a whirl... Might burn out some of the rats nests in the system...
Old 10-04-08, 07:51 AM   #6
Drazic
Issimo - where did you get those lovely Magnecor HT Leads from? I noticed the 5th one on mine, doesn't fit very snugly on the sparkplug anymore and I think it keeps coming loose, messing up the timing? I know Pete Reeve supplies them at quattro corner, but there £75 and was wondering whether there might be a cheaper souce?
Thanks and what a lovely engine!!
Drazic is offline   Reply With Quote
Old 10-04-08, 08:14 AM   #7
Alas, they too came from Pete Reeve... The previous owner fitted them, at first I wasn't too sure about them, but they've been fine.
Old 10-04-08, 08:36 AM   #8
Pull the wire out of the end( carefully ) and re-crimp the bit that grips the top of the spark plug. Should work they are all only ever crimped anyway.
Old 10-04-08, 09:18 AM   #9
Drazic
I see, many thanks for this! Will have a look at the weekend...
Old 10-04-08, 09:19 AM   #10
Drazic
How comes? I thought the Magnecor leads were meant to be excellent quality?
Bonnet pull for Coupe! 86audicoupe Parts Wanted 13 24-08-09 10:21 AM
Bonnet Chrome Trim & Bumper rubber Wanted - 100 Coupe MartyP Parts Wanted 2 18-05-09 01:11 PM
Wanted bonnet cable and attachments for 1987 style coupe mjl16v Parts Wanted 5 03-01-09 02:42 PM
