Classic Audi » Classifieds section » Parts Wanted » VDO / Stack Gauges
Old 18-10-09, 05:59 PM   #1
Default VDO / Stack Gauges
I am after a VDO water temp gauge, same size as the ones used in all the coupes, so 52mm diameter. The Coupes however did not use a water temp gauge as you know.
Also, should anyone have one lying around that they do not need or wish to sell, then a Stack Tachometer exactly like the one in the pic on the top right. The diameter of this is 80mm. Probably hoping a bit too much on this one though!!
Old 18-10-09, 08:26 PM   #2
Darron Edwards
Darron Edwards's Avatar
Try ebay for golf GTI, early ones had a lovely VDO water temperature gauge fitted.
Old 18-10-09, 09:17 PM   #3
l7apk
l7apk's Avatar
Hi Booty
you can get an 80mm vdo tacho up to 10,000 revs recalled for 5cyl, more authentic.
i'll look up the supplier if you like
l7apk is offline   Reply With Quote
Old 18-10-09, 09:22 PM   #4
l7apk
l7apk's Avatar
here we go, these guys are really helpful
http://www.etbinstruments.com/VDO_Range.htm
don't mention it
Old 18-10-09, 09:23 PM   #5
Rich, I've got a lot of gauges in the unit.
Not sure what off, but random Audi/VW parts throughout the years!
Old 18-10-09, 09:28 PM   #6
Tim C
Tim C's Avatar
I have this one. I think it came with a job lot on ebay when we were building our rally rep.
Could be from a series 3 coupe.
Not quite the same as the one you pictured but you are wlecome to it, if it fits the bill.
quattro RR - crystal silver
Old 18-10-09, 10:26 PM   #7
dubmeister
dubmeister's Avatar
The early GTI ones were oil temp (0-150 deg) in the console, water temp in the clocks.
Not sure if i have an oil temp one lying about, if thats any use, know i have def. got a voltmeter- will check
dubmeister is offline   Reply With Quote
Old 19-10-09, 08:53 PM   #8
don't mention it
Cheers Andy, but.........it absolutely has to be a Stack 80mm item, black background with a white needle..................you know how it is.
Old 19-10-09, 08:59 PM   #9
Audi Derek
“Been raced and rallied”
Audi Derek's Avatar
Found this one on the bay but its in the US of A..
http://cgi.ebay.com/ebaymotors/Stack...Q5fCarQ5fParts
Old 19-10-09, 09:04 PM   #10
Audi Derek
Audi Derek's Avatar
Or try a Porsche Tachometer look the same..
80 Sport VDO gauges Sie! Interior 0 18-01-10 11:07 PM
VDO Gauges Booty Parts Wanted 5 30-01-08 01:46 PM
