Classic Audi » Technical » Mech/Tech » Engine » 90Q 10V Idle/timing issues.
Prev Previous Post   Next Post Next
Old 13-08-09, 11:10 PM   #5
madwolf_uk
madwolf_uk's Avatar
If u can't set ignition by using marks, then adjust it with feel - it's not 10vt/20v/20vt where certain degrees are needed otherwise there will be no spark
Brand new knock sensor will not help with iddle, it will make it run better above iddle speed.
How about nozzles - have u checked them?
I assume you mean injectors? Havent checked them, but seeing as there fine above 1500 RPM id imagine they should be ok below that as well?
Hopefully getting use of a timing gun this weekend to put the timing issue aside once and for all....
madwolf_uk is offline   Reply With Quote
Engine issues trying my patience again 20vcqdriver Engine 3 13-07-09 07:40 PM
Timing Belt poopcoupe Technical Info 10 15-04-09 08:17 PM
Running Issues on my 80 2.0 8v 3A sport? Donald_MacIver Engine 5 31-01-09 05:43 PM
Timing belt and Oil filter... slick578 Engine 2 17-04-08 10:24 AM
