Members: 19,823 | Total Threads: 40,096 | Total Posts: 471,133 Currently Active Users: 3749 (0 members and 3749 guests) Welcome to our newest member, BuddyInons |
Morning Gents,
My mechanic requires the crakshaft locking tool i.e. the one that locks the pulley to undo the 27 mm bolt (280nm) to change the cambelt etc. Anyone know where I maybe able to source borrow one? The local Audi dealerships have apparently lost theirs!! Many thanks in advance Doug |
Audi do sell them about 25 quid. I hope your man knows his tools cause to undo that bolt with it's 380lb ft of torque it goes with a bloody bang I can tell you. Really need to ensure the locking tool is correctly inplace also as they can slip, then the guy holding the scaffolding bar ( cause that's what you need to undo it ) slips and spends two weeks with concussion. I had the job of sitting on the floor with my feet pushing on the end of the extension bar keeping it on the end of the bolt pulling on the bottom valance for stability. When the bolt went, I could have cried cause I thought the head had sheared. It hadn't but by God what a job..............Don't forget the loctite on the bolt after either.
where about are you ............. i have one here
and the correct touqe for the bolt is 350nm on a CQ and 350nm on a UR and if you don't have the other locking tool it's 450nm. ![]() |
#4 | |
Thanks for the advice on the removal and reinstatement - tricks of the trade ey!! |
Thanks! I suspect it will probably be worthwhile and more cost effective to buy the tool to give to the garage whenever needed, but thanks nontheless. It all sounds very complicated to me!! I have an Audi 90 quattro and they advised my mechanic that it was 280nm - have Audi got this wrong then? ![]() |
I wasn't far off with 380 lb ft was I. Still a bast*rd to do.
You decided to keep her then Doug
#10 | |
Audi don't have it wrong your spanner man has. ![]() ![]() i have checked and double checked it 450nm the locking tool is 2084 if only useing this the toque IS 450nm if useing 2079 & 2084 the touque is 350nm. tell your spanner man to check & he'll find he's wrong and may end up oweing you a engine rebuild |
| strut top removal tool | pimpdriver | Suspension & Brakes | 28 | 24-02-10 10:16 PM |
| central locking | Micky | Bodywork, glass & exterior fitments | 6 | 07-08-09 02:52 PM |
| kv head bolt tool | audicoupeparts | Engine | 2 | 11-02-09 05:52 PM |
| Central Locking Pump - '82 200 5E | one trick phoney | Electrical problems | 6 | 25-09-08 02:52 PM |
| 2226 | Booty | General Chat | 17 | 05-03-08 08:33 PM |
