Members: 19,823 | Total Threads: 40,095 | Total Posts: 471,121 Currently Active Users: 3604 (0 members and 3604 guests) Welcome to our newest member, BuddyInons |
My rad is leaking when it gets really hot, I have found the leak, it is near the top.
![]() I have a spare radiator, any tips for changing it??? I have done a Mk2 GOlf one before. It looks fairly simple, but how hard is it to bleed??? Which coolant should I get, G12? (pink stuff???) |
Go to Halfrauds and get some Bar-leaks putty (or whatever it's called) and whack that in the hole... Strong as an ox if you follow the instructions...
Alternatively, change the rad... ![]() Should be a simple swap, change the bushes too, then bleed as normal. Run engine with heater on (that'll be nice, this weather!) and top up as necessary. G12 is the stuff...
#3 | |
I have been driving along with the heater on full blast for the past couple of days to get the heat out of the engine so the water wasn't as hot so I could open the expansion tank lid and put some more water in. Joy of joys!!!!! |
#4 | |
the hole is where the fins are, do I just ram the putty into the fins???
like this: http://www.halfords.com/webapp/wcs/s...Id_165691#dtab it has pictures of taps and radiators on the packet so should be good. I will change the coolant and flush it out though, it needs doing (which is why it could have failed in the first place, the corrosion inhibitors have gone........) And get billy bonus points off the Mrs for not spending ages on the BLOODY CAR |
I can't remember the stuff I used (without going down the garage), but I inadvertently stuffed a Stanley knife blade into a rad whilst bearing wire, it pee'd fluid even when the pump wasn't running. Whacked some similar stuff over it and packed out the fins to an area about the size of an old 50p piece...
Promised I'd change the rad as soon as possible... Car was destroyed by local youth 8 months later and over 3000 miles, without loosing a mm from the header bottle max line...
for £4.69 it has got to be worth a go. And if I tried to change the rad, guaranteed it would go wrong!!!!
Hmmmmthe pearl had a blow job yesterday due to a blockage
Just work it into the fins deep the first time, because if it sets and the leak isn't cured, you've got to pack it from the reverse side... So don't be shy of it... Better to loose a small area of fins and fix the leak than go all soft and smear a bit over the fins, and not fix the leak.
got the G12++ coolant today, £24 frigging quid for 4.5 litres from VW. I tried to go to Bath Audi, but when I got there, they had moved out of Bath.........
And I got the putty, as well as some deionised water...... Getting T4 exhaust welded tomorrow, so 100 radiator on Sunday....... |
| Audi 100 radiator woes | pimpdriver | Engine | 10 | 14-09-09 04:17 PM |
| Audi Coupe Gt / Quattro Radiator Complete With Fan | tony | Parts For Sale | 0 | 23-06-09 05:11 PM |
| radiator for my audi 80 1975!! | xXbullXx | Parts Wanted | 8 | 23-01-09 09:10 PM |
| Advice needed on changing my Audi | SteveCat | General Chat | 1 | 14-02-08 10:46 PM |
