Classic Audi » Technical » Mech/Tech » Wheels & Tyres » wheel bolts length !? :(
Old 12-05-09, 07:08 PM   #1
I may have some spare bolts you can have. I got loads with my new wheels. I'll ship them out with the cam if you want to try them, there not much use to me.
Old 12-05-09, 07:10 PM   #2
just an idea just push a standard bolt threw a standard wheel and see how mutch sticks out
Old 12-05-09, 07:15 PM   #3
Probably a better/easier method Micky... Saves having to clean up the threads afterwards...
ISTR standard are 35mm, 40mm are available too.... (don't quote me on that though).
Old 12-05-09, 07:21 PM   #4
vag80
vag80's Avatar
If your car has drums on the rear be carefull with the lenth of bolt you use i have had it before were i've fitted longer bolts only to find they were alittle to long and were catching on the brake shoes.
if you have discs all round then it's no prob
200k club member
87-b3 80
83-4000 2 door
Old 12-05-09, 07:22 PM   #5
Good point....
Had that with my old GT... Had the longer bolts machined down a bit...
Old 12-05-09, 07:39 PM   #6
You should have at least 6 - 7 full turns on a bolt. I had these issues with my Ronal when i fitted the spacers. Demon Tweeks helped out and sold me 16 of their longest. Give them a call ( infact pop in as it's only down the road from you ).
Old 12-05-09, 07:51 PM   #7
Gaz
Gaz's Avatar
how much did that set you back?
If the bolts from Emjay don't fit I might indeed pop to demon tweeks. thanks
Old 13-06-09, 12:53 PM   #8
Gaz
Gaz's Avatar
emjays bolts were too thin.
quick question, what size thread does my car use?
also, whats should be the correct bolt width?
cheers.
Old 13-06-09, 05:13 PM   #9
M14 x 1.5 is what you need.
You'll need tapered seats for aftermarket wheels
Old 12-05-09, 07:42 PM   #10
Gaz
Gaz's Avatar
That sounds great!
With any luck they might do the job!
thanks.
20 off wheel bolts for steel wheels pimpdriver Parts Wanted 2 02-12-09 08:18 AM
speedline rivits/bolts Tone Wheels & Tyres 4 27-08-09 07:48 AM
Name that wheel! Puglife General Chat 22 11-08-09 08:12 PM
oil cooler shield bolts stuartmmcfc Bodywork, glass & exterior fitments 8 05-08-09 07:44 PM
Speedlines & dummy bolts on ebay rsk289 Parts For Sale 2 06-03-09 10:40 AM
