Classic Audi » Technical » Mech/Tech » Electrical problems » 80 Sport Electrical Gremlins
Old 16-04-09, 05:43 PM   #1
b2_sport
b2_sport's Avatar
Default 80 Sport Electrical Gremlins
When the indicator is ticking the voltage meter ticks as well, moves left & right very slightly, and when the lights are turned on the volt meter drops a tad. Is this normal? If it is normal I did not realise the volt meter is so live!
Also the oil temp stays very low like it is not working ? What should be the normal running temp for a B2 Sport? Maybe my temp sensor is dodgy.
Do these cars have a bad earth problem? I am wondering whether a weak earth is causing these issues, I was planning on re-earthing the car over the weekend just in case it is that.
Sorry if these look like stupid posts, I just don't know anything about a B2 Sport!
Old 16-04-09, 06:06 PM   #2
I'd check your earth's as it's more than likely just a bad earth which is causing it.
Unless your thraping your sport then temp will sit at about 80-90.
Old 16-04-09, 06:22 PM   #3
b2_sport
b2_sport's Avatar
Thanks for that Coxy, my temp needle sits just above 60. I think I may have a dogdy temp sender. Will look into replacing that, I have got a haynes manual which came with the car so will get a bit anal over it on the weekend.
Old 16-04-09, 08:09 PM   #4
BigT80
IMHO movements on the VM are quite normal; esp the latter. As Coxy says OT gauge usually 70 - 80 unless hammered or on long high speed motorway run, but I've have one that's up around 90 in a few miles. I don't think they are that accurate! Could be sensor: these are still around, but check connection first the tiny spade connection can fall off or internal wires break but look fine because outer sheath still in tact. Cheers.
BigT80 is offline   Reply With Quote
Old 16-04-09, 08:12 PM   #5
My Voltmeter is up and down like a brides drawers depending what I have switched on. Strangely the blower fan really draws on the volts.
Old 16-04-09, 08:17 PM   #6
b2_sport
b2_sport's Avatar
Thanks for the replies. Do your gauges light up at night with the lights on? Everything else lights up on the dash apart from the centre gauges. Are they supposed to light up?
Old 16-04-09, 09:02 PM   #7
kully
kully's Avatar
Yes, they have small bulbs in them, easy to change
Old 18-04-09, 08:00 PM   #8
b2_sport
b2_sport's Avatar
I broke two of them trying to pull them out, lucky i did not cut my fingers. I had a look in local Halfrauds, could not find these buls.
Where shall I get them from....see attached image.
Old 19-04-09, 12:46 AM   #9
In every shop that's big enough - bulbs like theese ones are in every B3, B4, C3, C4 [and newer ones too] - two of them in every switch in center console, three for heater controls [B2 have one for that], one for cigarette lighter and so on. That's one thing that I don't have problems to get in this banana republic i'm living
Coxy, how do u imagine bad earth in this case when dashboard's wiring harness have only one ground wire for all stuff in dashboard[except some optional equipment that have additional ground connection]?
Old 19-04-09, 10:12 AM   #10
kully
kully's Avatar
get them from audi, they have them no problems
electrical gremlins? Gaz Electrical problems 3 19-11-09 06:38 PM
kv engine gremlins irish80sport Engine 9 01-11-09 08:31 PM
Electrical gremlins strike again Emjay Electrical problems 1 17-05-09 07:50 PM
electrical fault bart simpson Engine 2 20-02-09 11:31 PM
electrical fault bart simpson Electrical problems 3 17-02-09 09:08 PM
