Classic Audi » Technical » Mech/Tech » Engine » Could it be the Cold Start Valve?
Old 23-08-23, 07:12 PM   #31
Ringmaster
Ringmaster's Avatar
Originally Posted by ovalking View Post
I got 60ohms (ambient temp).
I don't think it's your problem, but you need to monitor the cold start valve supply voltage to check its operation. It only comes on for 3 or 4 secs at most. This is detailed in the Haynes.
Edit: because forum can't display ohms symbol!
Thank you..
Old 31-08-23, 11:16 AM   #32
Ringmaster
Ringmaster's Avatar
Fuel pump replaced... issue remains...
Old 01-09-23, 09:01 AM   #33
BackintheFold
BackintheFold's Avatar
BTW.. I have discovered another trick... If I just turn the ignition on and off (without starting the engine) twice and then turn the engine on, the car starts up and drives well. Sometimes the engine surges from 800 to 1100 rpm when idling, but otherwise OK..
It's definitely pointing to a problem pump or return valve...
I don't think this points to a "dumb" component, as I can't see why the start up procedure would do anything to the fuel pump and non return valve.
It says to me its an electrical/sensor issue.
I regrert I can't be more help with what one!
2006 A3 (daily drive)
1987 MB ur
Old 02-09-23, 10:49 AM   #34
Ringmaster
Ringmaster's Avatar
Thanks anyway.. more food for thought.
I was considering the thermotime switch when I noticed the problem is less severe when engine was warm. I have now noticed a misfire... alas the saga continues...
Old 02-09-23, 12:21 PM   #35
BackintheFold
Disconnect sensors one at a time.
When one is unplugged that makes no difference to the problem-that's the duff sensor.
Used to do that all the time for spark plugs/leads.
1987 MB ur
Old 09-09-23, 12:59 PM   #36
Ringmaster
Ringmaster's Avatar
Is it a Eureka moment!? I hope so... But there is a twist...
Had the emissions checked at my local MOT centre and it was running very lean. CO showed as 0.4. They set it to 3.3 and engine seemed a little smoother. However I needed to see how it did from a cold start.
As I left the centre all my brakes seized up!!! Same problem I had 2 months ago! My mechanic found a brake fluid leak back then but no obvious cause. He drained the brake fluid and all has been well since then. Managed to limp home without setting fire to the brakes! I heard clunking noises from behind the dash and the rear, just like the last time.
Left it for 3 days as I wanted to see how it did from a cold start and it fired up well today. No stalling!!! And the brakes had freed themselves. But this is what I've noticed...
Engine revs tend to surge to 1100 rpm. Engine has an occasional faint blip.
If I rev the engine the revs drop to 1100 for a while before falling to 800 rpm.
I heard a click from the engine area when this was happening.
When I push the brake pedal the engine revs, sometimes up to 1100 rpm.
Is there any way the engine could cause all four wheels to lock up?
Or, can the brake system be affecting the engine in any way?
Some sort of vacuum pressure issue?
Old 11-09-23, 03:48 PM   #37
BackintheFold
Could your brake servo be buggered?
It has a vacuum line.
1987 MB ur
Old 11-09-23, 06:48 PM   #38
84CoupeGT
84CoupeGT's Avatar
There is a non-return valve between the servo and the vacuum hose which goes to the intake manifold, I wonder if that is failing or loose? Or as Backinthefold says, you may have an issue with the servo itself.
Old 11-09-23, 09:16 PM   #39
Ringmaster
Ringmaster's Avatar
Thanks chaps. I was just thinking that...
I'm having trouble spotting the non return valve on 7zap.
A faulty valve may explain why the brakes are failing intermittently.
Old 12-09-23, 08:42 AM   #40
tractor Dave
Not up on C3 model but have you got a traditional servo or a hydraulic brake booster and bomb?
