Members: 43,081 | Total Threads: 40,086 | Total Posts: 471,053 Currently Active Users: 15248 (2 members and 15246 guests) Welcome to our newest member, Scottmat |
#11 | |
Will sure do.
And yes, i probably won't need it, but it's also a fun exercise ![]() Last edited by maartenmoerman; 21-09-21 at 10:25 PM. |
#12 |
On my Cq I have A4 288mm up front and 256mm rear and never had rear lock up issues.
I have the Audi Driver/VWAUDI car issues that I wrote for the rears. The 256mm discs are solid discs from the front of a Mk3 Golf TDi and have the correct offset and just need the holes changing to suit. Fortunately we have a good workshop at work that allows me to do the necessary alterations. On the mounting side I filled the original holes and re-drilled and tapped the mounts 5.5mm further out and used the original calipers. No issues in the 19 years since
![]() Coupe quattro 1986:-~450bhp + loooong list of mods! Audi A7 Bi-TDI SLine Black edition 2015 mapped to produce 600lb/ft torque! Audi S4 4.2 V8 cabriolet 2004:- Last edited by 20vcqdriver; 22-09-21 at 07:54 AM. |
#13 | |
What wheel size are you going with? How much machining work are you willing to undertake or have done on the discs? If it's not important, and having something off the shelf to fit straight away is a low priority, then the only real limitation may be the height of the disc. And even that can be overcome. What's the thickness of the front disc? Other than the Q7, unless I'm mistaken, Audi have a 68mm front bore. I'm toying with the idea of Mercedes disks which are 67mm, but in my case I'd rather not be doing any machining work on the service items. I want to be able to buy disks and pads, and fit them. Machining work being only necessary on the hardware to get a brake conversion done in the first place. In your case, normal PCD is 108mm. But if you're willing to drill the disks as needed, then this is a small issue.
#14 |
jogi
One other option is to speak to Alex at Ultraperformance.
No idea of cost for your application, but he will make discs for you to your specification. https://www.ultraperformance.co.uk/audi-s2rs2?page=1 I have no connection to them other than the fact I am using their dual brake booster conversion kit, one of the best mods I have made to my car.
#15 | |
I have no problem doing some work, as i just like to have a very nice solution ![]() *edit* Ow, and one other thing that let me to 280mm discs is, i wanted to run nice shiny red porsche calipers, and i didn't want to upgrade the B2 front struts to the (different mounting for calipers) B3 front struts. Last edited by maartenmoerman; 06-10-21 at 08:55 AM. |
#16 | |
#17 | |
#18 | |
