Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Coupe GT front suspension
Old 12-08-21, 01:20 PM   #21
84CoupeGT
84CoupeGT's Avatar
Originally Posted by mikes2 View Post
You must have the earlier type bush.
The later ones come with a split in the place you describe to make fitting easier.
Cheers Mike. Fingers crossed should be ok to cut them then
Old 30-08-21, 02:40 PM   #22
84CoupeGT
84CoupeGT's Avatar
Had some time to work on the car last week and got the front struts off and apart. I'll be replacing the hubs as one was damaged, and the wheel bearings as well as one in particular had quite a bit of movement in it.
One of the shocks seems ok, but I think the other may have had it - it is extremely stiff (it can only just be moved by hand), it also gurgles/grinds a bit and is leaking slightly.
Any recommendations/ brands to avoid for the shocks? Thought maybe Sachs/Boge as the originals are Boge. Or TRW, Bilstein, KYB... Suspension is staying original spec and I'm more interested in the car riding as original.
Cheers
Old 30-08-21, 08:56 PM   #23
Duffy3074
I’ve used both KYB and Sachs and rate them both, equally
Old 31-08-21, 06:58 PM   #24
Seconded!
Old 31-08-21, 10:29 PM   #25
84CoupeGT
84CoupeGT's Avatar
Thanks very much both, very helpful
Old 31-08-21, 10:32 PM   #26
Duffy3074
KYB are OEM for Subaru and they’re fairly sturdy cars
Sachs are OEM for a lot of German firms, you’ll not go wrong with either
Old 07-09-21, 10:24 PM   #27
84CoupeGT
84CoupeGT's Avatar
Anyone know the torque settings for the gearbox mount bolt please? The one that goes through the rubber mounting/bush at the gearbox end of the "arm" that links to the subframe mounting point. I ended up replacing the rubber mount in the end as I noticed a split.
Also, I presume it's ok to fully tighten the above and the subframe bolts with the car in the air? I know the wishbone pivot bolts and anti roll bar nuts should be torqued up on the ground.
Cheers!
Old 08-09-21, 08:44 AM   #28
tractor Dave
What engine do you have? Haynes manual gives two settings depending on engine and gearbox fitted.
Old 08-09-21, 08:59 AM   #29
84CoupeGT
84CoupeGT's Avatar
Cheers Dave, it's the 2,144cc 5 cylinder "KE" engine. 5 speed gearbox, code "HC"
Many thanks
Old 08-09-21, 12:15 PM   #30
tractor Dave
