Classic Audi » Technical » Mech/Tech » Engine » Engine Check light
Old 11-07-20, 11:46 AM   #1
Tun
Tun's Avatar
Default Engine Check light
Out for a little drive this morning and this light came on probably 3 times while accelerating but went off when I eased off. Anyone got any ideas what to check?
1988 MB quattro
2012 S4 Avant
Old 13-07-20, 10:00 AM   #2
BackintheFold
BackintheFold's Avatar
An MB with less than 30K miles? Might be the lambda probe playing up!
Or engine knock sensor-how long has the fuel been in? was the most recent fill up low quality?
Old 13-07-20, 02:45 PM   #3
vagdream
I seem to recall having to replace the knock sensor on my MB many years ago (at least 15) for a similar reason.
vagdream is offline   Reply With Quote
Old 13-07-20, 02:59 PM   #4
You need to pull codes as the ecu will store it when that light flashes.
Fuse in the fuel pump relay to trigger the code sequence
1991 90 quattro
Old 14-07-20, 06:53 AM   #5
Tun
Tun's Avatar
Thanks Mike, am I right in thinking the MB erasers the codes when you switch the ignition off or have I just imagined it?
1988 MB quattro
2012 S4 Avant
Old 14-07-20, 07:43 AM   #6
Tun
Tun's Avatar
30K I wish, the milage is approximately 100,000 more than shown. The history and HPI reports suggest there was a problem with the dash. MOT in 1999 recorded 91644 next MOT in 2001 shows 3998.
The MB, or at least my MB, does not have a lambda sensor so I can rule that one out, and I always run super unleaded, it was last filled up about 6 weeks ago.
1988 MB quattro
2012 S4 Avant
Old 14-07-20, 08:17 AM   #7
Think you might be right.
Best idea is to take it for a run and recreate the fault again. Pull the codes when you return without switching off.
Only time I had that when accelerating, it was the inlet air temp sender in the intercooler - wiring had come away
1991 90 quattro
Old 14-07-20, 09:15 AM   #8
BackintheFold
Phil Payne mentions the o2 sensor-in that when it dies (at around 30,000 miles) tape over or remove the warning light. I did find that odd but had no reason to question it.
EDIT This is for North American models only.
i can confirm that the codes are lost when you switch off.
Old 10-09-20, 06:48 AM   #9
Tun
Tun's Avatar
Update.
Finally managed to read the codes (remembered to do it before turning the engine off ), code 2142: engine knock sensor. New ones don't appear to be available so I replaced it with a Bosch 0 261 231 040 on advice from Pete Reeve. It is a bolt through one, fitting was as you would expect (PITA) due to it's cramped location. Only done a couple of short trips but no reoccurrance of the blinking light so hopefully all is well again.
1988 MB quattro
2012 S4 Avant
Old 10-09-20, 08:35 AM   #10
vagdream
Same solution ( ex P Reeve) 15 years ago as well!
