Classic Audi » Technical » Mech/Tech » Interior » What Glue for interior trim plastics?
Old 23-03-18, 02:25 PM   #1
Default What Glue for interior trim plastics?
What's likely to be a low mess, high impact plastic glue for discreatly repairing the door card lower door pockets on a B2 interior...?
I don't really want a snot fest and have seen so many 'world's best glue for gluing glue to glue... EVER'...bollocks, that frankly, I'd sooner go with a decent recommendation....
Many thanks in advance.
Ian
Old 23-03-18, 03:50 PM   #2
vorsprung durch technik
Anything 3M is always very good.
Old 23-03-18, 05:28 PM   #3
Davids
What bits are you actually sticking? is the actual plastic or is it cloth trim to plastic ?
David
Davids is offline   Reply With Quote
Old 23-03-18, 08:01 PM   #4
darreno'd'
Mr Sixty Thousand!!
darreno'd''s Avatar
Superglue and baking powder
http://www.oesems.co.uk/
Old 24-03-18, 06:55 AM   #5
Originally Posted by Davids View Post
What bits are you actually sticking? is in
nn the actual plastic or is it cloth trim to plastic ?
David
To clarify, it's plastic to plastic, the door pockets back to the broken plastic screw holders. It's really hard to explain, but put simply, if we put small things in the door pockets they can drop out the bottom when you open the door.
Old 25-03-18, 11:34 AM   #6
SwallownAmazon
SwallownAmazon's Avatar
Sorry to be a bit of a pessimist but take it from one who was at one time an adhesives chemist, nothing will effect a permanent repair except "welding" the broken parts together with heat. An alternative would be a mechanical fixing of some sort.
I had to repair a broken ABS fixing lug on one of the front sidelights of my BMW 740 Sport recently; I did that by using pins to splint the broken parts together and then burying the pins in polyurethane sealant. The sealant still peels off the ABS but the repair is sufficiently strong to hold it together. (New "crystal" sidelight for the facelift E38 is approx £130! )
Old 25-03-18, 01:52 PM   #7
Davids
I had to repair my door panel as one was cracked, also the only thing we ever found that was near to successful for plastic repairs was a very good PU adhesive, Sikaflex or Wurth PU adhesive sealants are very good.
Nothing will repair successfully edge to edge but if you can get a bead behind, and even better if you can reinforce with some thin ally, perforated is best, then this can be successful.
My door card don't move now with this method and I was even able to wipe a bit of the PU into the facing part of the crack which helped to disguise it,
I have done a few door cards and bits of trim with a plastic bumper weld kit but you also need to paint really after this.
Give it a go with a tube of PU adhesive, degrease well, rough bonding surfaces, secure after gluing with tape o something like this and give it a good few days to go off before you touch it.
Cheers
David
