Classic Audi » Technical » Mech/Tech » Electrical problems » Battery light not going out.
Prev Previous Post   Next Post Next
Old 19-03-18, 09:02 AM   #3
Sounds like the replacement alternator is faulty? If you remove/disconnect the small wire from the alternator and the light goes out then alternator has an issue. If light stays on then suspect wiring or problem behind clocks/dash.
If engine cranks ok then I'd not worry about adding a separate earth lead, just make sure the alternator is secure and earthed to bracket/engine.
Does the B2 have a flashing oil warning light like mk1 Golf?
