Classic Audi » Technical » Mech/Tech » Engine » Engine fault codes
Old 20-11-17, 11:23 PM   #11
Colin Aitchison
Colin Aitchison's Avatar
Is the spring inside the rotor arm or is it part of the distributor?[/quote]
Rotor arm below with rev limiter built in, as the rotor arm spins getting faster and faster the centrifugal force acting on the rev limiter spring ( green circle ) allows the rev limiter plunger to move in direction of the red arrow and fires to a different cylinder.
Old 22-11-17, 01:13 PM   #12
hotsnot
My rotor arm isn't like that, it's like this
hotsnot is offline   Reply With Quote
Old 22-11-17, 09:56 PM   #13
Andy10v
Andy10v's Avatar
Does this version of CIS have a rev limit in the fuel pump relay?
2005 350z GT
Sold-1993 ABY coupe
Old 22-11-17, 11:50 PM   #14
vorsprung durch technik
Can't see the other side of it but it looks like a standard Bosch rotor arm so it won't have a rev limiter built in it.
Old 23-11-17, 09:42 AM   #15
hotsnot
The garage did replace the fuel pump relay, where is it located as it's not where I thought it would be under the bonnet, so I can check they fitted the correct one?
Old 23-11-17, 02:00 PM   #16
That's the normal fail when a 4 cyl fuel pump relay is used in a 5 cyl car.
FPR should be in the main fuse box in the engine bay on an 87 ?
Old 23-11-17, 04:06 PM   #17
hotsnot
Relay is looking like it could be the culprit...interesting read. When I put my VRN into car parts websites it comes up as a 90hp model.
http://www.clubgti.com/archive/index.php/t-188590.html
Old 23-11-17, 05:07 PM   #18
hotsnot
Ok, found it. The fuse box cover doesn't list it as that.
Old 23-11-17, 07:10 PM   #19
Is it a GT or Audi Coupe ?
What was the original engine as the 90hp 1.8 were never called GT. That was reserved for the 1.8i, 2.0i and 2.2i for the 87 cars.
Old 23-11-17, 09:17 PM   #20
hotsnot
GT, does anyone have the correct pt number for the relay?
