Classic Audi » Technical » Mech/Tech » Suspension & Brakes » chopped springs
Old 06-03-09, 08:27 PM   #11
first of all, I'd give it chance to settle.
As you've only just put them on.
Old 06-03-09, 09:20 PM   #12
Just a thought, an old trick I remember from some of the guys in the SCCA. Auto -Crossers in early VW Golfs and Hondas put the springs in the oven at 500 degrees F. for some hours, which as I understand it relaxed the spring by SMALL intervals. I believe this gave them very specific ride heights with a variety of wheel combinations.
I have not done this, and am no expert. Just putting it out there for discussion.
Old 06-03-09, 09:23 PM   #13
I seem to recall they did that with spring compressors on... Is that true...?
Old 06-03-09, 09:35 PM   #14
Yeh, sounds right. I'm checking with some old Auto-X buddies now.
Stay tuned.
Old 06-03-09, 10:00 PM   #15
Theres another aspect to this besides the spring rate change that cutting the spring will achieve, and thats the fact that springs and dampers are a matched pair.
Suspension engineers go to great lengths to ensure that a dmaper is matched to the spring it has to control.
Its a bit like pushing someone on a swing where if you time it right theyll go higher and higher as each push adds momentum, wheras if you time it wrong theyll stall and slow down -which is what a damper does to a spring.
Anytime the rate of the spring is altered, youll need to alter the damping rates to best match the new rate.
If you dont youll get a spring thats not being controlled correctly leading to pitching, poor control of the tyre over undulations and bumps, you can end up with a car thats got lengthened stopping distances also.
Best to go the whole hog and get a kit where the dampers and springs are matched.
Old 06-03-09, 11:40 PM   #16
its not big and its not clever. dont do it
Old 07-03-09, 12:34 AM   #17
Yeah, just like he said......nuff said!!
Old 07-03-09, 07:54 AM   #18
dandan
big gimping
dandan's Avatar
right ok, the reason i say chop a coil off is simply i can not find a set 80mm springs anywhere, they make them for the golf and jetta but thats all i can find, i aint doing it for better handling, remember its an old diesel not a quattro. il ride on the 60mm another month, i think maybe 15's might make it look lower by filling the arch better. will post pics soon.
dandan is offline   Reply With Quote
Old 07-03-09, 07:56 AM   #19
put a couple of bags of sand in the boot!
and a full tank of juice will help as well!
Old 07-03-09, 08:21 AM   #20
coilovers???
air bags?
Get some piccies up of it now, and we'll have a vote to let you know if you need to go lower.
UR Springs stumack7 Suspension & Brakes 1 14-05-09 04:19 PM
G Max Springs poopcoupe General Chat 9 23-04-09 10:35 PM
CQ rear springs Daveymaclad Parts Wanted 0 15-03-09 04:32 PM
Uprated springs quattropower Parts Wanted 0 23-01-09 09:37 PM
Lowered Springs. Coxy Suspension & Brakes 38 29-11-07 02:18 PM
