Classic Audi » Technical » Mech/Tech » Engine » Cracked exhaust manifold
Old 13-01-08, 09:19 PM   #1
randall977
Mr Typ 43!
randall977's Avatar
Default Cracked exhaust manifold
What is my best course of action for sorting out my cracked manifold (off a 1982 200 5T, engine code WJ)? Repair, replace?
Old 13-01-08, 10:39 PM   #2
90Quattro
90Quattro's Avatar
either try and find someone willing to weld it or go tubular!!!
Old 13-01-08, 11:47 PM   #3
Default weld it
i had mine welded 18 months ago and its still ok all you need to do is find someone who knows what thay are doing
john...
Old 14-01-08, 09:13 AM   #4
randall977
Mr Typ 43!
randall977's Avatar
Anyone know of anyone in the Oxfordshire area who knows what they wre doing with a welder?
Old 14-01-08, 06:19 PM   #5
crisarc
Default manifold
any decent welder should be able , i did it , v grooved the cracks slightly, buzzed it ap /ground back and same again, it was no problem, BUT I DID REPLACE THE ENGINE MOUNT ON THAT SIDE just to be sure that the manifold took less strain
Old 14-01-08, 07:55 PM   #6
Default hi chris
hi there chris hows the RS2 going you old sausage all the best and a happy new year
john... your q.o.c. area rep
Old 14-01-08, 08:51 PM   #7
crisarc
is that you dad? RS2 is good , some new paint , new stat, the beast lives....., 200q has a treser double intercooler , new belts, etc[winter overhaul], saab 900t soon new ic /leather carlsson gauges, .....what else? coupe q will be done this decade starting the body....may go for the kermit green body with satin bonnet/boot....scala43.de if you are bored...nb i am looking aftermy neighbours honda 400 four p plate, classy, will i see you at cosford?
Old 14-01-08, 10:25 PM   #8
randall977
Mr Typ 43!
randall977's Avatar
Gave the manifold to a guy at a local fabrication / welding workshop - he seemed to think he could weld it - and for £20/30!!
Old 14-01-08, 10:37 PM   #9
randall977
Mr Typ 43!
randall977's Avatar
There is about a 5mm gap between the sump and crossmember - should it be more? Where can new mounts be purchased?
Old 14-01-08, 10:45 PM   #10
crisarc
Default manifold
5mm sounds a bit tight, try vag parts, your local dealer, or south hereford audi , but quattro corner is likely your best bet i would think that the ur quattro mount is the same,i certainly used one on my 2005t no probs, , the mounts get tired over the years, coupled with the heat on ths exhaust side of the engine, if you replace it buy or fabricate a heat shield to help with the heat soak.
regards chris
Need Exhaust From Manifold tommyboy Engine 4 19-07-09 10:32 PM
Exhaust Manifold andy e Engine 0 29-03-09 01:03 AM
Dialynx exhaust manifold. 4v6 General Chat 12 02-03-09 09:57 PM
exhaust manifold VW 2.4d I-5 non-turbo knobstar Parts For Sale 0 10-09-08 04:35 PM
Ur exhaust manifold 4v6 Parts Wanted 15 07-02-08 06:04 PM
