Classic Audi » Technical » Mech/Tech » Electrical problems » Heater blower problems
Old 30-10-16, 11:41 AM   #1
vag80
vag80's Avatar
Default Heater blower problems
Hi does anyone know where I can get a wiring diagram for the heater blower system for a b3 80, as my blower fan is only working on speed 1&2 and nothing at all on 3&4 if anyone has any idea what's wrong that would I would be grateful cheers
200k club member
87-b3 80
83-4000 2 door
Old 30-10-16, 12:56 PM   #2
Ben
This is for the AC but the fan wiring should be mostly the same:
1992 80 quattro 20vt
Old 30-10-16, 02:43 PM   #3
If the fans working on a couple of speeds but not the others thats usually a sign of a blown heater motor rheostat, shouldnt be huge money and a second hand unit will more than likely fix it,
Old 30-10-16, 03:43 PM   #4
vag80
vag80's Avatar
4v6 are you on about the resistor on top of the blower motor housing
200k club member
87-b3 80
83-4000 2 door
Old 30-10-16, 05:48 PM   #5
cjp0349
'Heater motor rheostat' also known as THE SWITCH
Old 31-10-16, 02:19 PM   #6
I think youre right!
Old 05-01-17, 11:40 PM   #7
Cynical26
Cynical26's Avatar
I only had a blower on speed 4. Replaced the heating resistor on top of the blower, pain in the arse but quick, and hey presto: all 4 speeds work again!
Cynical26 is offline   Reply With Quote
Old 06-01-17, 07:59 AM   #8
Tun
Tun's Avatar
I had same problem on my 90, resistor on blower motor was the culprit. Hides behind the glove box. Find and press locking tab and twist/turn the motor and lift it out to get access
This is the part from memory.
http://www.ebay.co.uk/itm/NEW-Audi-8...wAAOSws65TrFVk
1988 MB quattro
2012 S4 Avant
