Classic Audi » Technical » Mech/Tech » Engine » Car won't start intermittently ['87 200 Quattro Turbo]
Old 09-10-15, 04:10 PM   #1
leggy
Originally Posted by John Clayton View Post
Good call.
The other thing that I forgot to say is that (when it won't start in the above manner) it always then seems to fire up OK when you jump it off another vehicle.
Originally Posted by Groundhog View Post
If indeed it starts with a jump from another vehicle, and assuming you are connecting jump leads to the battery, then the only thing you are by-passing is your own battery so unless we are missing another piece of info are you sure your battery is 100%? Cars like these,especially as they get older, need a good battery that can spin the engine over with conviction.
Same as John Clayton, mine would jump start no problem, well, up until the day I broke down anyway. As Groundhog states, you do need a good battery to be able to turn the older cars over.
FWIW, back then my boy was eating batteries, at a rate of one/year, all cheap makes, and with the coil pack fault to boot, well, it's hardly surprising that the battery didn't have enough oompf left to start my boy on the day I broke down, it/they barely had the oompf to start my car.
(NOTE: I have since invested in a decent battery! )
Old 14-11-15, 03:23 PM   #2
John Clayton
It had a new battery last year and if it was a poor battery, I think the problem would occur consistently (rather than erratically).
Angus went through the diagnostic process but no fault codes came up. Maybe we will have to just drive it until the problem reoccurs and then immediately go through the diagnostics again?
John Clayton is offline   Reply With Quote
Old 09-12-17, 05:58 PM   #3
Modus
Mine does this, sometimes. Is it a problem with the electronics or injection not always working properly if the voltage is slightly down during cranking of the engine?
Modus is offline   Reply With Quote
Old 16-12-17, 09:42 PM   #4
Modus
Starting from warm is still very difficult:
It turns over for longer than normal & fires up on one cylinder for a while, then two, then more but rather roughly for a while.
It seems to be running rich.
I described the symptoms to a Quattro expert and he said that it could need either of the following parts to cure it:
1. Warm up regulator -bimetallic strip £300+VAT exchange (they rebuild your own Regulator, but it takes 5 wks to do). N.B. It is not normally possible to rebuild it yourself as it needs to be set up to the correct tolerances etc.
2. THERMO-TIMESWITCH £75+VAT
The recommended course of action we were given is:
a) use the car daily until the problem appears. As soon as the problem arises then check if engine has a spark at the coil, fuel etc.
b) change the Regulator first and see if it cures the problem
c) if not then change the timeswitch.
However, my mate drove the car and reckons that although it is boosting up to the right sort of pressure (I think it is going up to 1.8 bar), it is not pulling as hard as you would expect, so something may not be 100% within the engine's current set up at all times (not just on start up)
Old 03-01-18, 06:49 PM   #5
Modus
similar problem here:
2.2 Turbo starting problems
http://audifans.net/ftopict-7541.html
