Classic Audi » Technical » Mech/Tech » Electrical problems » drivers door lock not working with the key phob :(
Old 10-02-09, 03:45 AM   #1
Gaz
Gaz's Avatar
Default drivers door lock not working with the key phob :(
a couple of days ago the drivers door lock stopped working when i press the alarm button on the key phob.
any idea whats most likely gone wrong?
I suppose i need to take a look, but can't be arsed in this weather.
I just hope it simply needs a new motor maybe? I just hope it isn't the alarm it self that has c@cked up.
Anyone else had this problem? I guessing all this cold weather has done something to it.
Old 10-02-09, 08:16 AM   #2
I presume this is the pneumatic type locking system?
Youll likely have either an obstruction of some kind preventing the actuator from locking the door or an air leak to that actuator so it dosent get full vacuum pressure.
Could be something as silly as a pipe off or split, or possibly trapped.
Old 10-02-09, 10:10 AM   #3
Martc
Black Coupe Collector
Martc's Avatar
Could even be its iced up perhaps?
95 UrS6
87 Coupe Quattro
Old 10-02-09, 10:54 AM   #4
steveb
steveb's Avatar
The coupes never had remote locking so it will be an aftermarket fitment could be as simple as the rod has come of connecting the actuator to the door locking mech. only way to know is to take the trim off and have a look . I take it the cetral locking works if you use the key ?
[FONT]
'76 Leyland Princess 2200 HLS
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
[/color][/size][/font]
Old 10-02-09, 06:35 PM   #5
if its the key fob it could be the battery in it ,does it lock with the key ?
Old 10-02-09, 09:23 PM   #6
Gaz
Gaz's Avatar
The battery works fine, as i can still 'ARM & DIS-ARM' the alarm/immobilizer.
The key doesn't turn the lock in the drivers door. it never has since i bought the car. I'm guessing someone has replaced the mechanism that opens the door, but forgot to swap the key barrels over.
The passenger door lock has never centrally locked either, I know this uses a 'pneumatic' type system.. so i'm guessing its a hose issue or something.
however, i'm 90 % sure that the drivers side on these cars uses an electric motor. as you can usually hear it swiftly lock and unlock. (or you could before it broke) So now its just silent, and does nothing.
On my GT however, its broken in a different way. the vacuum works on the passenger door, but you can here the motor in the drivers side spinning away to its self but not being able to lock the door.
Old 10-02-09, 09:25 PM   #7
that's normal for the passenger door.
The central locking only enables from the driver's door
key don't work in drivers door?? Gaz Bodywork, glass & exterior fitments 2 07-12-09 04:02 PM
Broken door lock Ringmaster General Chat 8 30-09-08 08:04 AM
Drivers door bump strip a25c Parts Wanted 2 28-09-08 11:58 PM
Drivers side door trim '82 GT5 snorky Parts Wanted 11 26-09-08 11:01 AM
type 85 80/90 door lock barrel/s and key spink Parts Wanted 5 31-07-08 06:11 PM
