Classic Audi » Classifieds section » Parts Wanted » Anyone know where I can get one of these....
Old 16-02-15, 09:17 PM   #1
Flying Frank
Flying Frank's Avatar
Default Anyone know where I can get one of these....
...Spent a while today removing the bonnet catch "springs" from the front apron, then went onto removing the bonnet release cable. On the very end of the cable is a cone shaped end piece with a tapping screw to hold the cable from sliding back through the O/S spring. On removal the screw sheared off...and the cone shaped bit which has the wire running through it has the wire "welded" in to it with rust so a new part is required ....any ideas or links please? ( Audi 80 Sport, B2 )
Old 16-02-15, 09:22 PM   #2
Default Is this it?Not cheap.
http://www.ebay.co.uk/itm/NEW-BONNET...item3cf3067745
KARL.
Old 16-02-15, 09:29 PM   #3
Flying Frank
Many thanks, I'd seen this item in the distant past, but couldn't remember exactly where. You are red hot on the "knowledge" Much appreciated .
Old 16-02-15, 09:29 PM   #4
Hanuman
Hanuman's Avatar
http://p-arts.ch/index.php?a=461&lang=eng
From the land of raclette
Old 16-02-15, 09:37 PM   #5
shaun5
shaun5's Avatar
would this be the same as whats used on B4 cars? if so ive probably got one
Old 16-02-15, 09:53 PM   #6
Flying Frank
Thanks Shaun and Mark, but have now splashed out over £20 for that part from classicquattro. Wouldn't mind so much if I had a UR quattro but.... for a humble 80 Sport it's a lot of dosh. Bloody thing has so much rust everywhere it's costing a fortune in penetrating oil !! The smaller stuff just sheers/breaks.
Old 16-02-15, 10:18 PM   #7
sinbin5t
sinbin5t's Avatar
You will be like me now Frank forever hearing Pshht from using penetrating oil that much
And does your mug of tea slip out of your hand yet
Old 16-02-15, 10:39 PM   #8
Steev
Steev's Avatar
Frank keep going my friend. Walk away for a week if you have to. Look on it as a holiday exercise not a job. No one's timing you here, we all know what bastards these fecking things are. A mistress would be easier to handle....... ( open discussion)
Audi Coupe S (1972)
Audi WR Turbo (1987)
NSU RO 80 1975 (look it up!)
Old 16-02-15, 11:19 PM   #9
quattrodave
Quick and cheap fix is a bycycle brake cable cllip if you not bothered about orginality.
Old 17-02-15, 08:14 AM   #10
Flying Frank
Tried that, got the "T" shirt a couple of times which is why I am now such a poor pensioner! Words like "some people never learn" spring to mind.....
One advantage of old age is that the temptation tempered by realisation makes that option a non starter!!
Thanks for the kind advice Steev !!
