Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Front Brake Conversion - Sanity Check
Old 08-09-14, 12:31 PM   #11
Addicted
Do you know what caliper was originally fitted? i.e the one paired with the 239mm solid disc?
1985 Type 81 2 door 2.8 V6
1983 Golf GTI track weapon
1977 Scirocco G60
1968 Sand Rail
Old 08-09-14, 01:25 PM   #12
Not without checking up and that will take a few days. IRC they came of a Golf but that's about as far as I know for know
What are you thinking?
Old 08-09-14, 03:09 PM   #13
Addicted
Just doing the maths as to whether you really do need a 22mm master cylinder (rather than taking it as fact from forums )
If we take the mk1 golf, that had the VWII caliper with a 20mm master cylinder. The VWII has IIRC a piston diamter of 37mm. That gives a ratio of 11:1
The mk2 golf 16v, with the Girling 54 caliper had a 22mm master cylinder. That gives an improved ratio of 12:1
So if you upgrade to Girling 54's but keep the 20mm master cylinder you end up with 14.5:1
Thats quite a bit. With servo assistance that will give quite a lot of pedal travel.
Now the 256mm Girling 54 setup I have came off a B2 Audi, therefore there must be a B2 Audi with a 22mm cylinder, would that not be suitable for you?
1977 Scirocco G60
1968 Sand Rail
Old 09-09-14, 07:58 PM   #14
re edited my original post as follows for accuracy
Blimey this brake upgrade thing is a bit of effort. Having sourced and confirmed the front caliper set-up I've started the search for a 22mm bore tandem brake cylinder. So far I've identified two potentials. One is from a Scirroco 16 valve and the other is from a Coupe.
The only down side to both is the fact there is no way to fit the brake light switch. If anyone knows of a unit that can also take the brake light switch I'd be interested to hear from you.
Thanks
Martyn
Old 09-09-14, 08:48 PM   #15
Addicted
Right, you're not going to like this.. But..
You have the mk1 golf type master cylinder and servo, depending on year it may even have a 171 part number (mk1 golf number). Its made by ATE and is 20.64mm diameter.
With that servo you cannot upgrade to a 22.2mm master cylinder, you have to swap the servo also as the interface is different. This where it gets tricky as the servo for the 22mm master cylinder is of a bigger diameter (9" diameter) and may not fit your bay due to fouling brackets etc.. As you probably have a 7" servo (you need to check)
Also, the 22mm master cylinders only have 4 m10x1.0 outlets. Which means you need to insert T pieces in your front and rear lines for the brake light switches. Or fit the brake light switch from an auto which is on the pedal.
If you have a 9" servo you're laughing as you can just swap in the new servo and master cylinder assembly
One of the old school conversions was to use a merc SL master cylinder, fits existing servo, uses existing fluid reservoir, one port for rear brakes, one port for fronts and one for switch...
1977 Scirocco G60
1968 Sand Rail
Old 10-09-14, 11:19 AM   #16
tbh that's very helpful as it gives a clearer indication of what I'm dealing with.
On the positive side, tee-ing in the brake light switch is easier than wiring in a new light switch under the brake pedal so if that's feasible then that's a big plus.
Going to see if I can hunt out a Merc master cylinder and measure up the servo situation
Old 10-09-14, 12:19 PM   #17
Addicted
I just googled the merc master cylinder.. looks like it has a 19mm piston for rear brakes and a 23.8mm piston for the front... strikes me that would take careful setting up, unless my memory is fuddled and it was a different merc master cylinder people used.
I had one on a GTI 20 years ago and I'm sure it had 23 cast into the side (used it with some AP calipers)
EDIT:
This looks perfect! from a typ 44! Audi part number 443611021. 23mm, same servo, same reservoir, 4 M10 x 1.0 ports... and its genuine ATE
http://www.ebay.co.uk/itm/BRAKE-MAST...item2ecac802f7
1977 Scirocco G60
1968 Sand Rail
Old 10-09-14, 01:21 PM   #18
funnily enough the Porsche 924/944 had a similar split MC. 19mmm for the rear and 23 for the front brakes for Bias set up
Old 10-09-14, 06:06 PM   #19
ChrisG
ChrisG's Avatar
I've run 256 front on my 80 Sport for many years.
I didn't change the master cylinder ( at the time didn't want the extra hassle as the car was a daily driver then.)
The pedal travel is a bit longer but the brakes still work well !
I keep thinking I should complete the job....and it wouldn't matter if it was off the road for a month!
Old 10-09-14, 06:43 PM   #20
Addicted
Does it only have a 19mm master cylinder? I thought the 256's were standard on the 80 sport..
1977 Scirocco G60
1968 Sand Rail
