Classic Audi » Technical » Mech/Tech » Engine » more power wanted for aan engine
Old 30-01-09, 05:31 PM   #1
100turbo c
100turbo c's Avatar
Send a message via AIM to 100turbo c
Default more power wanted for aan engine
i want more power out of my s4 , apart from chipping or remapping any othern good options ? cheers
100turbo c is offline   Reply With Quote
Old 30-01-09, 10:06 PM   #2
martinjs
How much power do you want?
1992 UrS4
martinjs is offline   Reply With Quote
Old 30-01-09, 10:21 PM   #3
That's a good question, the sky's the limit with a 20vT...
A remap and a bigger intercooler will see you knocking on the door of 300 (290ish). But, and this is a big But...
It's got to be spot on healthy first... Anything that resembles a weakness... sensors not working properly, boost leaks (a classic nightmare fault), fuel starvation at full boost etc will all become much bigger issues when upping the boost...
A kkk24k is good for circa 300bhp, anything after that is a turbo change... Conventional wisdom says 350 for standard rods, (achieved with RS2 inlet/exhaust etc) but I've seen 400 running standard bottom ends... Then, after the 'scat' rods and modified pistons rebuild on the bottom end and custom remap it's just a case of modified inlet, exhaust, turbo, intercooler and fuel/mixture control... All the way to the 1000bhp blocks...
Old 30-01-09, 10:25 PM   #4
Oh, I forgot, also a huge bank account, 20vT's are cheap hp in name only...
Yes, 285bhp can come cheap, but the jump to 315bhp/350bhp is expensive... The next 'expensive' jump is over the 380/400bhp (bottom end) hurdle.
Old 30-01-09, 10:29 PM   #5
4v6
Keeping within stock rev limits will go a long way towards keeping it all reliable.
Javed from 034 motorsport ran a 10valver -unopened engine btw, for two years in race trim at outputs of 500bhp ish before he lost a valve head which destroyed the motor.
20valvers got more potential for sure so i dont see 400bhp being beyond std components if detonation is avoided and fuelling and coolngs kept under control.
I certainly hope to see 400 bhp and then some on the 20 vt i have...
More power for NF engine pimpdriver Engine 3 14-08-09 05:09 PM
6a / ACE Engine Wanted T0MME Parts Wanted 1 09-06-09 08:49 PM
kg power 100turbo c Engine 2 23-11-08 09:52 PM
Wanted,both exh manifolds for a 2.6 V6 ABC engine SteveCat Parts Wanted 1 10-09-08 08:24 PM
