Classic Audi » Technical » Mech/Tech » Suspension & Brakes » urs4 porche brake conversion
Old 16-04-14, 02:08 PM   #1
ade-5
Default urs4 porche brake conversion
Alright guys im looking at doing a porche front brake conversion on the s4, thing is the coversion bracket, I know apikol sell one for $240 but I have someone who could make some if I can get the right measurements and specifications :-) so my massive favour is if anyone has made brought or fitted any of these brackets and could share some info :-) thanks in advance Ade
ade-5 is offline   Reply With Quote
Old 16-04-14, 02:34 PM   #2
spink
Have you got ufo's on your at present?if so have a look at this
http://www.s2forum.com/forum/showthread.php?t=49445
I have always found hp2s to be really good brakes,only down side is they are a big hefty.they are very cheap to buy aswell
i know jp(jnl racing) had over 500bhp and still had the hp2s on his s6 and found them perfectly good until he upped the power to over 650 ish
Old 16-04-14, 02:57 PM   #3
ade-5
Yeah has the ufo's on at the minute, that guide seems simple enough even for me lol, I was just under the Impression the hp2 wasn't that great either mmm
Old 16-04-14, 09:37 PM   #4
I like my HP2s.
There are a number positives-
Readily available. If a bit heavy. But overall, not significantly heavier than the UFO setup, if at all.
Disks are cheap from euro car parts.
Pads are a straight forward buy, too.
Downside? The mods I mentioned earlier. But you need mods for the Porsche, too.
Old 17-04-14, 02:41 AM   #5
ade-5
What did the hp2s come on as standard? Any later models?
Old 17-04-14, 04:02 AM   #6
UrS6, B5 S4, probably something else. Over here, in latvia, usual way is getting UrS6 struts and calipers to do bolt on upgrade.
Old 17-04-14, 07:09 AM   #7
Also, A8, etc. the basic parts are fairly common with minor differences, across a whole load of models- disks (diameter 314 or 323mm), pads, callipers (for 314 or 323mm).
However, the suspension/struts that they bolt too vary.
S6 struts are a straight bolt on upgrade as far as I can determine, for Type44 100/200 (but the bottom ball pin is a different size), Type44 early and late chassis-V8, A100/ur-S4, A6/urS6.
The mounting plate on the strut is pretty common across a large range of cars, and seemingly only the size/thread of the mounting holes makes any difference.
Old 17-04-14, 02:30 PM   #8
ade-5
So guys what do you think? Hp2 is the way to go? I know il be paying around £600 for a porche setup if not a little more. How much would a hp2 setup set me back?
