Classic Audi » Technical » Mech/Tech » Engine » ticking tappets
Old 16-11-13, 06:32 PM   #1
rizzo
rizzo's Avatar
Default ticking tappets
Hi guys,i know its pretty normal for the 5 cyl engine to have tappet noise if left for a day or two but has anyone found an oil or product that will overcome this problem,
cheers Bill
rizzo is offline   Reply With Quote
Old 16-11-13, 10:41 PM   #2
missfire
missfire's Avatar
15W40 mineral. seriously,
Old 16-11-13, 10:45 PM   #3
i tried this stuff which worked initially . . .
http://www.ebay.co.uk/itm/Wynns-Hydr...item2a2e3b8f54
but quickly goes back to the way it was, especially on a cold morning . .
Old 16-11-13, 10:55 PM   #4
Eddy
Eddy's Avatar
some times a good thin engine flush and service can help, with GOOD OIL.
Castrol, Mobil 1, Quantum, etc,etc, 15-40 semi or 10-60 fully synthetic
Old 16-11-13, 11:09 PM   #5
8690q
8690q's Avatar
The biggest problem I've always had with 5 cylinder engines is them sounding tappety after a good leadfoot workout. New, good oil and still I get it, maybe an oil cooler might be a good bet ?
I can live with the odd rattle when cold unless it takes ages to go away.
8690q is offline   Reply With Quote
Old 16-11-13, 11:13 PM   #6
Eddy
Eddy's Avatar
Yer, try a thicker oil or a cooler, esp if your turboed
Old 17-11-13, 12:07 AM   #7
age/engine type?
Old 17-11-13, 01:08 AM   #8
missfire
missfire's Avatar
It's a five cylinder audi engine.
Going by the door handles, 1988-1991 type 44 avant, i sayyy....... 2.3! NF
But don't know.
Old 17-11-13, 02:32 AM   #9
alex-qts
alex-qts's Avatar
I had noisy tappets on start-up when left for a while also, probibly normal considering the 206,000 miles! but I also read this:
As I mentioned previously, only use a genuine V.A.G. oil filter, or one from M.A.N. or Knecht (0C47 for general fit VW/Audi filter). These two last manufacturers make the filters for V.A.G., and you should find that they are cheaper than the ones from the dealers. These filters also contain a non-return valve which some of the cheaper filters do not have. This is to prevent the oil that is up on the top of the cylinder head from falling back down to the sump when the engine is switch off.
Going to give it a try as mine was running an aftermarket filter that had no non-retun valve. Makes sense that the oil would eventually drain back into the sump without the valve. Worth a try!! I will report back when I finally get mine started up again
Source: http://www.clubgti-sussex.co.uk/article/Tappet.htm
alex-qts is offline   Reply With Quote
Old 17-11-13, 12:39 PM   #10
rizzo
rizzo's Avatar
Thanks for replys chaps, the car is a 89 2.2 C3 quattro KU, so looks like quality 15/40 mineral and genuine filter is the best way to go, are we all agreed
cheers Bill
