Classic Audi » Technical » Mech/Tech » Wheels & Tyres » the wrong tyres
Old 14-01-09, 09:49 PM   #1
100turbo c
100turbo c's Avatar
Send a message via AIM to 100turbo c
Default the wrong tyres
on the 90 quattro i have just bought it has the wrong tyres fitted they are 60 profile instead of 50, could this make the car a lot slower as it does feel a bit slugish or is it just me
100turbo c is offline   Reply With Quote
Old 14-01-09, 09:58 PM   #2
if the profile is incorrect then you will get incorrect speedo readings. So if the profile is too high then the speedo reading will read too high and the car will be going slower. For example sppedo reading reads 70 but you are in reality travelling at 65 mph. So the car will feel sluggish. If the profile is too low then the opossite effect applies and you run the risk of speeding. Eg sppedo says 70 but in fact you are travelling at 75mph.
I use this as a great reference site http://www.carbibles.com/tyre_bible_pg2.html
Old 14-01-09, 10:04 PM   #3
you have no turbo and only 136bhp. And the extra quattro weight.
Old 14-01-09, 10:49 PM   #4
I suspect you should be running around the 195/55/15 mark for the tyres, maybe 205/55/15... But remember the wider the tyre the '50' or '55' is the % profile of the width. So the gearing is altered accordingly. However, I'd suggest you're looking at maybe another issue/aspiration as the profile alteration to acceleration is marginal from 55 profile to 60 profile.
I’d sling all the excess weight out (ask Puglife, he’s a man on a mission with scales), pump the tyres up, and check when there was a change of the plugs, leads, oil, filter, air filter, rotor, distributor cap. (coil maybe) and try again.
Old 15-01-09, 01:22 AM   #5
Gaz
Gaz's Avatar
id of thought if the car had a higher profile, the speedo will read 'less' ??? and likewise if you fitted very tiny wheels, the wheel would have to rotate many more times than normal to cove the same distance, so a smaller wheel/profile would give a false 'high' speedo reading respectively.
However, a taller wheel/tire will be harder for the engine to rotate. But having a 60 instead of a 55 wouldn't make a huge difference, as already stated.
Old 15-01-09, 11:30 AM   #6
20vcqdriver
20vcqdriver's Avatar
Default Standard
Standard 90 quattro tyres were 205/60/15. Only the S2 with 16" rims had a lower profile..
Old 15-01-09, 11:59 AM   #7
Gib
STD 90 tyres are 50 profile , 60 are for coupes i had a look at these and asked the , then current owner at CC if he had any rubbing issues as these are coupe wheels and also have the wrong ET. i have used coupe wheels before and it depends on the tyre as to if you get issues. From memory rubbing was only on the rear upper edge of the inner wing..
Old 16-01-09, 09:34 AM   #8
Your probably right, anyway it's one way round or the other and none the less wrong profile tyres will have an effect on speedo readings...I was high on a bottle of red when I posted
and look at the state of my spelling too, thats a comprehensive education for you!!
Old 16-01-09, 10:55 AM   #9
Jabber
I had 205/60/15s on mine when I first bought the car and when I had people in the back it rubbed on the rear arches, the B3 models never had 205's they run 195/50/15s and hey I don't rub no more!
Jabber is offline   Reply With Quote
Old 16-01-09, 02:31 PM   #10
look in side the filler cap or the handbook to find out what options should be fitted.
what else can go wrong thread Micky General Chat 6 02-01-10 11:27 AM
Is it wrong to really like this car? The Milkman General Chat 11 31-10-09 05:02 PM
Is it wrong to like this.....? Coxy General Chat 26 05-09-09 05:31 PM
Is it wrong to like this.....? Coxy General Chat 17 02-07-09 09:14 AM
WRONG...Wrong...wrong... Just wrong. Isimmo General Chat 5 29-06-09 10:18 PM
