Members: 19,806 | Total Threads: 40,093 | Total Posts: 471,106 Currently Active Users: 7263 (2 members and 7261 guests) Welcome to our newest member, AlbertAbato |
Please send me a PM if you've got one - part number is 054133154C.
Cheers, Nick |
May have one will look in the morning and get back to you .is this the early engine with the tubular manifold ?
Yes, tubular manifold.
May have one where in the country are you ?
Northamptonshire
Ragtop Collector
If Farmer Phil can't help you out send a message to Acidburn as he is breaking my old CQ 20v...
Right the unit I have here has the part number 051 133 154 A it has a black lead with a two pin connection and a three pin connection on the unit itself, this has come off a tubular manifold engine .
That's odd, ETKA lists 051 133 154A as the part for the F 8A-L-203 051>> chassis - ie. with the non-tubular manifold, which also appears to use a different throttle body. Perhaps yours is the later chassis but with the earlier manifold ? Or maybe the earlier chassis with the later throttle body ? If it's the latter then it would suggest that one solution might be to swap the complete throttle body.
Any thoughts ? |
Is the wiring the same ? if not then there would be a problem ,I have striped quite a few of these ( mainly the none tubular engines ) but they always have had this unit .Only thing I can think is it may be the latter engine that some one has put the tubular manifold on not sure.
Right just been out to look at a 90 20v which I bought some time ago ,this has a tubular manifold ,I have taken off the throttle body and the unit has the right part number on it (054 133 154 C ) so I do have the right part ,it has hitachi on the top and a four point plug .
