Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Audi 90 brakes + locks
Old 23-11-08, 10:13 PM   #1
Indrid Cold
Default Audi 90 brakes + locks
I've just bought a h reg 20v 90 it needs a couple of bits done before i can drive it though, so i have a couple of questions someone on here might be able to answer
firstly the previous owner broke the only key in the ignition (how i have no idea) will all the locks from a 80 coupe fit a 90 saloon (i'm bidding on a set on ebay).
The rear brakes are needing work it definitley needs disks and pads but i think it might need calipers as well as the handbrake binds on,
do calipers from any newer VAG car fit maybe from a A4 as i know all to well about the handbrake calipers on early 90s audis and vws and if i need to replace them i might as well fit better ones.
Indrid Cold is offline   Reply With Quote
Old 24-11-08, 09:19 AM   #2
joe90
Hi there indrid, you could always try a locksmith to remove the broken key and they should be able to cut you a new key, i had a mates uncle do one for me a few years ago.
Bryan
Old 24-11-08, 02:23 PM   #3
You should be able to get a new barrel for the car and then get a locksmith to re configer the door lock barrel to match
Old 24-11-08, 07:24 PM   #4
joe90
I did have a barrel a key kicking about but it is a while since i have seen it, i will have a look around through the week and see if i can find it.
Bryan
Old 24-11-08, 10:10 PM   #5
steveb
steveb's Avatar
saloon and coupe do not have the same locks strange as it may seem pop over to audifans .net there is a thread about it.
[FONT]
'76 Leyland Princess 2200 HLS
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
[/color][/size][/font]
Old 24-11-08, 10:47 PM   #6
steveb
steveb's Avatar
Steering lock could be but the door locks def. are not
[FONT]
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
Old 24-11-08, 10:58 PM   #7
Indrid Cold
Thanks, I'll have a look once they arrive, might just be a case of putting them back on ebay though. unless i can use the internals of the coupe ones in the original barrels (i've rebuilt locks like that before on a vw but it was using parts from the same model) though they are probably different.
I saw the thread on audifans.net, you would have though the barrels would be the same on the saloon and coupe though.
Old 24-11-08, 11:53 PM   #8
one trick phoney
one trick phoney's Avatar
Many years ago I had to replace the ignition barrel/steering lock on a car that had been stolen. I got one from a main dealer (based on the chassis number) and it came with a set of keys that also matched the door and boot lock. Silly question - hav you tried a main dealer?
Audi 200 5E
Subaru Forester XT
On-One Inbred 456
one trick phoney is offline   Reply With Quote
Rear brakes Audi 80 Bowma Suspension & Brakes 4 29-01-10 11:03 PM
UFO brakes on Audi V8? NBirkitt Suspension & Brakes 0 25-05-09 05:01 PM
Audi Coupe Quattro Brakes and Fleix Pipes Martc Suspension & Brakes 23 20-04-09 09:56 PM
Wanted New brake discs for a '71 Audi 100LS (inboard brakes) mattp Parts Wanted 6 07-08-08 01:03 PM
Audi 100 brakes problem pimpdriver Suspension & Brakes 3 01-02-08 10:16 PM
