Classic Audi » Technical » Mech/Tech » Suspension & Brakes » Rear Brake Carrier Mounting Bolts!!!
Old 17-08-11, 11:45 AM   #1
Andy Douglas
Andy Douglas's Avatar
Default Rear Brake Carrier Mounting Bolts!!!
What the best method of removing the rear brake carrier bolts, the hex.head ones that hold the carrier to the strut!! all friendly attempts have failedmine's a 90q but they are all similar.
Thanks Andy
No Audi at Present
MGF VVC
Honda CRV (daily wife bus)
Peugeot Expert (work van)
VW Polo 1.9 TDI No 1 sons 1st VAG car
Andy Douglas is offline   Reply With Quote
Old 17-08-11, 12:04 PM   #2
Phil Payne
Banned
I've never had a serious problem with them - you have to be careful to clean the head out, then hammer the driver in and put a wrench on. Did four on a car last week.
Otherwise angle grind the head off.
Old 17-08-11, 12:09 PM   #3
Andy Douglas
Thanks Phil Got them soaking with penatrating fluid I'll try later.
No Audi at Present
MGF VVC
Old 17-08-11, 12:40 PM   #4
Phil Payne
Banned
Another little trick is to grind the chamfer off the very end of the driver to create a sharp edge. The the driver will scrape the rust off as you tap it in. You can pull it out, get rid of the rust, and tap it in again.
Old 17-08-11, 12:44 PM   #5
quattrostyle
you can also try to hit the head of the hex bolt from the side, give it a few hard knocks then hammer the driver in and off they come.
Old 18-08-11, 07:45 AM   #6
the other option is a set of these
http://www.uktools.com/irwin-5pc-bol...s-p-11525.html
You'll need new bolts afterwards but sounds like you need them anyway
Old 18-08-11, 09:57 AM   #7
Phil Payne
Banned
Originally Posted by mikes2 View Post
You won't get them on - there's no clearance for anything fitting AROUND the head.
I use these things as hammer-on sockets - no idea what they're called:
http://www.isham-research.co.uk/quat...ges/socket.jpg
But they're only 1/4" drive - even the 3/8" one won't go on. Not very good for an undoing torque often over 120Nm.
Old 18-08-11, 01:15 PM   #8
Andy Douglas
Job done N/S bolts no problem, O/S had to resort to angle grinder!! so thats the brakes done for a while now,new discs and pads all round and of course new mounting bolts,vast improvment to braking!!!
Now to find where the gearbox oil dripping onto the front exhaust is coming from!! THE JOYS
No Audi at Present
MGF VVC
