Classic Audi » Classifieds section » Parts Wanted » 1990 Audi 2309cc 20v Coupe Quattro
Old 24-03-11, 05:17 PM   #31
wildoliver
The other cable is for the light in the dash display.
It can only be the sender unit now, you've eliminated the gauge/wire must be the sender.
wildoliver is offline   Reply With Quote
Old 24-03-11, 05:35 PM   #32
ksaudi
Thanks for quick reply.
To date, no one has mentioned having a Sender for sale. Have I got to buy a new one or is it worth starting a fresh thread for one?
Oh, I may have explained it badly or am being thick, but I don't understand why the other cable on the Sender is for a dash light
As always, thanks for all the help.
Keith
ksaudi is offline   Reply With Quote
Old 24-03-11, 05:41 PM   #33
wildoliver
Autocheck oil pressure warning is the other wire.
BMWs in scrap yards give up the senders too
Old 24-03-11, 06:56 PM   #34
Keith
Because existing oil pressure senders are just switches, but manometer, for logical reasons, needs analog signal, so sender for it provides resistance that varies according to applied pressure, and to avoid need to drill a new hole in block or have one spare with plug in it, that sender provides both needed functions.
Pressure gauge, when not connected, goes up until max like yours does, and temp gauge doesn't moves. The same result for pressure gauge can be achieved if it's connected to incorrect pin on sender.
Old 24-03-11, 06:58 PM   #35
Are you sure these BMW senders provides correct signal? Which BMW has oil pressure gauge?
Old 24-03-11, 07:14 PM   #36
ksaudi
Thanks for comments.
Losing me a little regarding Temp Gauge as the wiring diagram seems to show it entirely separate from Pressure Gauge with its own sensor.
What do you suggest I try before purchasing Sender?
Many thanks
Old 24-03-11, 07:42 PM   #37
Actually it's a bit hard to understand your situation from your comments [and I didn't tried hard], so what are you doing - are you installing aux gauges in car which doesn't have them and never had before? What parts do you have?
Yes, temp sender is totally different [and small] and it's in different place as well - in 5 pot engines it's mounted in oil pump in front of engine. I forgot was it on right [driver's in UK] side or front, I think front. Wire originally goes around engine on it's right side. If your car doesn't have any mud guards below engine compartment, you should see it relatively easy - there will be either sender or plug in it's place.
Old 24-03-11, 07:50 PM   #38
ksaudi
Original Pressure Gauge (not fitting extras) which flies to max when ignition on. Looking at large Sender near Rad (UK Passenger/Nearside). My other posts above say what we have tried.
Thanks.
Old 24-03-11, 08:26 PM   #39
You have only one bare gauge and nothing else? Where are you planning to put it?
As I said earlier, it's normal that that gauge goes max without proper sender connected.
Old 24-03-11, 08:35 PM   #40
ksaudi
It is an original Gauge, i.e. the car is fitted (original equipment) with Oil Temp, Oil Pressure and Volt Gauges.
As already stated we have tried a new temporary Sender to Gauge cable but without success.
General feeling seems to be that it is a faulty Sender.
We are happy to try anything else.
Thanks
