Members: 19,823 | Total Threads: 40,095 | Total Posts: 471,118 Currently Active Users: 1606 (1 members and 1605 guests) Welcome to our newest member, BuddyInons |
recent running prob on my 200 with ur 20 3b engine,
on warm up its runs for a bit then conks out, when warm it runs better, but even better with the aux air valve disconnected, ![]() no boost leaks, new white and black pin sensors at the back of the head, question is does the aav on the motronic have a constant power feed or does it vary? if so what controls it? i have also changed the aav, but to no avail, it runs ok with the aav disconnected ,,, but i need to know ![]() oh and today the push rod on the clutch master snapped , in the middle of wolverhampton, had to use the starter to get it going and crash change it home.... ![]() oh what a day ![]()
hey! don't damage that beautiful car!
![]() ![]() phone Green Flag next time....! ![]() |
is this the same thing...??
http://www.isham-research.co.uk/quat..._air_test.html k-jet one different...? ![]() . |
mine was rough on starting from cold until i replaced the Lambda probe. Also are you sure non of the small vac / pressure hoses at back of inlet have perished /crushed?
the hoses are ok, all new, i disconnected the maf and it idled better, not sure about the lambda, i need to understand the system, ive had the maf and lambda in 4 years now and 50k, are the maf and lambda service items?
if so where would i go?
dont know if the k jet is the same as the motronic aav?
#7 | |
erm, where do i find these, idle switch, and fuses please
right, new hall senders x2, new plug leads, new rotor arm, new dizzy cap. and finally re wired the warm up sensor [white pin /back of the head], and we have a smooth idle , turns out my rotor arm, had contacted the internals on the cap , ,,, well you can imagine,[my fault, as i had not replaced it properly]
all seems well, only the maf and lambda to go ,[budget] just as well i have aquired,,,,,,,,,,,
