Classic Audi » Technical » Mech/Tech » Electrical problems » A4 Auto - Stuck in Park - No Brake Lights !
Old 16-12-10, 06:42 PM   #1
TheTwelveQuidKid
TheTwelveQuidKid's Avatar
Default FIXED A4 Auto - Stuck in Park - No Brake Lights !
GF's A4 (1997) been great until now. This afternoon, she started it up, pressed the brake pedal and the auto selector lever wouldn't move out of park.
I had a look and the brake lights are not working either. I noticed there are 2 switches on the brake pedal, and one has a cable going into it as well as the wiring connector. I tried bypassing each switch individually but neither put the brake lights on or activated the solenoid.
I checked the fuses and they all seemed to be ok (was going dark so I could have missed one).
The surround for the gear selector is metal with a rubber bit round it. I don't know if it just clips in, and I didn't want to risk breaking anything so I left it and lent her another car.
But for now it's stuck in her works car park which isn't good, so can anyone tell me what to do next, or what might be wrong. And how to take off the gear lever surround and bypass the solenoid that's stopping it going into drive ?
Any info on which fuse does the brake lights would also be really appreciated.
Old 16-12-10, 08:39 PM   #2
latent
latent's Avatar
some auto cars have a lock switch which allows you to only move the lever out of park with brake depressed - you can hear it as a light click when you press the brake pedal sometimes. The electrical signal for this comes from the brake light switch. Possible the brake light switch has gone down or a break in the wire which explains why no brake lights aswell. Id go for that before the solenoid
latent is offline   Reply With Quote
Old 16-12-10, 08:42 PM   #3
spongebob
spongebob's Avatar
could be brake light switch. similar thing happened on my golf gti dsg (automatic) except our brake lights kept randomly coming on when parked up, flatten the battery one night. was told on gti forum would be brake light switch. anyway with the battery charged up and back on the car I disconnected the brake light switch to make brake lights go out and make sure they wouldn't drain the battery again while a new switch was ordered and with the switch disconnected the gearbox wouldn't release from park. there a common thing to go apparently. best of all only cost £8.52 from vw
spongebob is offline   Reply With Quote
Old 16-12-10, 08:45 PM   #4
steveb
steveb's Avatar
Have you checked the brake light bulbs ?
[FONT]
'76 Leyland Princess 2200 HLS
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
[/color][/size][/font]
Old 16-12-10, 09:01 PM   #5
tttoptotty
tttoptotty's Avatar
Had a similar thing in the old Rangie let off handbrake (obviously not on a hill) foot on footbrake and put into neutral and then try it. I worked for me failing that make sure stupid I know but make sure it is actually fully in Park and if not it will lock the brakes and you cant put in any gear until it's in full lock on park this also found out in the Rangie but it might work for you hun. Sorry if you've already tried this.
Audi the ride of your life
Old 16-12-10, 11:51 PM   #6
TheTwelveQuidKid
Thanks for the replies.
We're going to have to move it tomorrow as she finishes for Christmas and the gates will be locked until the new year. I'll tow it if I have to but knowing it's probably some daft electrical fault it would be nice to suss out what's wrong and fix it.
Old 17-12-10, 09:28 AM   #7
yeti
You'll need a spec truck, autos stuck in park don't move easily.
Unless it's a quattro, then the best of luck to you
2003 Cors-arrrgh
Old 17-12-10, 10:52 AM   #8
20vcqdriver
20vcqdriver's Avatar
If you feel upto it you can fool it by removing one of the brake lamps, put side lamps on and using a spare wire put 12V from the centre connector of brake lamp and centre connector of side lamp holder this should be the same as pressing the brake pedal and should at least get it out of park, will need two people mind one to hold wire and one to pull it out of park.
But would certainly suspect switch.
Old 17-12-10, 05:15 PM   #9
TheTwelveQuidKid
Fixed.
Was a fuse.
Thanks for all the replies and ideas.
