Classic Audi » Technical » Mech/Tech » Electrical problems » Quick Q: What does this do?
Old 31-08-08, 01:56 PM   #1
moomin
Default Quick Q: What does this do?
What does this do and what happens if it's no longer there? The switch under the TB not the plug obviously :P
Thanking you
Old 31-08-08, 02:00 PM   #2
isnt that the inlet air temp sensor?
Old 31-08-08, 02:58 PM   #3
Looks a bit like the idle/full throttle contact switch plug.....but cant remember if thats present in your application?
What model?
Old 31-08-08, 03:36 PM   #4
20vcqdriver
20vcqdriver's Avatar
Default switch
Wired to a switch under the body and is made when throttle shut. To do with idle stabilisation system. If not working/connected you may get uneven or low idle.
Old 31-08-08, 05:11 PM   #5
moomin
sorry its on a JS engine Coupe GT5E b reg, switched depressed when throttle is closed.
Reason is i'm replacing the throttle body with a larger version and was wondering whether it could be deleted save me making up a bracket.
Old 31-08-08, 06:19 PM   #6
You sure you cant just drill and tap the larger throttle body to accept the switch?
Cant see as youll get any performance advantage to be honest as the JS was 115bhp iirc and its not going to be able to induct enough air to utilise the extra area of a larger throttle body, in other words any restrictions lie elsewhere.
Old 31-08-08, 07:34 PM   #7
If it won't make any difference (and 4V6 DEFFO knows his stuff), and it is a KV throttle body, sell it to me for my 80 Sport DZ engine.........
Old 31-08-08, 09:44 PM   #8
moomin
Its not a KV throttle body, it's not even from the VAG range
Thanks for advice on switch
Old 31-08-08, 09:51 PM   #9
Ooooh you little munkey! Being all coy and covert about it!
Hope the mod goes well.
Old 01-09-08, 04:42 PM   #10
moomin
Cheers, don't worry i'll be tapping you up for some more advice soon
Quick Poll stuartmmcfc General Chat 22 28-01-10 03:07 PM
quick one! andy Engine 10 09-10-09 04:36 PM
