Classic Audi » Classifieds section » Parts Wanted » Boot Screw/Plastic Clips/Light Seals?
Old 24-08-08, 07:34 PM   #1
Sie!
Default Boot Screw/Plastic Clips/Light Seals?
Hi there,
Yet again I want some tedius parts!
What I am looking for this time is some of the plastic push in screws that hold the piece of plastic on to the car thats located at the back in the boot seal area (The black piece that goes between the lights, with the section for the boot lock to fit through, it holds the boot liner in place). Im looking for 5 (I think, forgot to check that bit!)
Its for a 1985 Audi 80.
Also, does anyone know what is used exactly as the seal for the rear lights? Its like a black gum sort of stuff, and I would like to renew mine as I think they are letting in water. I have a full set of spare rear lights but not the seals..... Typical!
Many thanks in advance,
Sie!
Ps. I hope ive been clear on exactly what I want, if not I can get a couple of pictures.
Old 24-08-08, 07:43 PM   #2
Ohhh I do tis this stuff for the lights
Old 24-08-08, 07:49 PM   #3
can you take a pic of the clip things you want. I can't quite understand it from reading.
Steve
Old 25-08-08, 07:07 PM   #4
Sie!
Hi Steve,
Yeah certainly I will, just give me an hour or so.....
Sie!
Old 26-08-08, 09:33 PM   #5
BigT80
Didn't know you could still get that. I use the old dum dum paste which works pretty well & is probably cheaper.
Old 27-08-08, 03:00 PM   #6
Sie!
You can still get that.... but at a price of £25! Cant quite believe that..... (Thanks for that Amanda!).
Anyone know of something I can use in its place? Im am not sure just what 'dum dum paste' is? I want something that will seal it well, but I can remove again easily enough should the need be, and wont look out of place/a mess!
As for the boot clip Steve, I know my description was vague to say the least, so I have included a couple of pictures below of exactly what I want. I need those little plastic clip things (6 if possible, 5 would do), and they hold that piece of trim/plastic on.
Many thanks,
Sie!
Old 29-08-08, 09:29 PM   #7
BigT80
Hi Sie, I've got some of these clips you can have - may only be 3 or 4 that are in tact. Not home currently tho. - can check next week if you don't get sorted meantime. As for 'dum dum'. It is virtually the same as the factory Audi stuff that Amanda showed a pic of, but you have to mould it to the appropriate shape - like plasticine - comes in a tub. You can get it from 'Frost' for about £10: it will do about 3 rear light sets or more. I've used it successfully as I said. Have not tried taking lights back out though: it is a bit more sticky than the Audi stuff, but not permanent like some sealant in a tube. Anyway; food for thought. Cheers.
Old 29-08-08, 10:03 PM   #8
steveb
steveb's Avatar
Those clips look like ones that hold the wheel arches to the undertray on an A4 little cross head screw in the middle ?
[FONT]
'76 Leyland Princess 2200 HLS
'79 Scirocco storm
'84 WR
'89 coupe quattro
'01 A2 1.4 TDI SE
'14 A3 1.4 TFSI COD
[/color][/size][/font]
is it possable to change a fan belt with a screw driver well it is now kerker21 General Chat 1 10-12-09 05:39 AM
Plastic window on my Cabby SPECKY Car detailing & polishing 0 29-08-09 06:54 PM
Ur quattro Fuel enrichment screw Isimmo Engine 7 13-05-09 06:49 AM
best place to get injector seals?? laura80 General Chat 5 02-03-09 10:54 PM
brake seals pimpdriver Suspension & Brakes 4 20-04-08 07:19 AM
