Classic Audi » Classifieds section » Parts Wanted » Idle sensor plug needed 9020v
Old 14-09-10, 09:53 PM   #1
ian20v
ian20v's Avatar
Default Idle sensor plug needed 9020v
Anyone got an idle sensor plug for 7a engine as mine has disintigrated,now she's idling rough,still drives ok.cheers!
Old 16-09-10, 12:54 PM   #2
wildoliver
Is it the actual plug on the loom? If so I can probably cut one off a loom for you.
wildoliver is offline   Reply With Quote
Old 16-09-10, 04:26 PM   #3
ian20v
ian20v's Avatar
Its the insert on the plug i need,2 very thin wires were attached to this,was gonna solder it straight on as haven't been able to source one,if you've got one, great news!
Old 16-09-10, 11:02 PM   #4
wildoliver
If you mean the actual ISV I do have these but not actually talking about one in this case.
If you mean the actual bit that clips on to the ISV the plug with 2 wires and the clip then I can snip one off a loom for you with pleasure.
Old 17-09-10, 11:06 AM   #5
ian20v
ian20v's Avatar
That would be great m8 i'll pm you my address,cheers its the plug with 2 wires and clip as mentioned
