Classic Audi » Technical » Mech/Tech » Engine » Big End Shells
Old 11-09-10, 04:34 PM   #1
Garrick
Garrick's Avatar
Default Big End Shells
Anyone now where I can get set from?
There actaully for a Mk1 golf GTI DX code, however probably the same as alot of audi's too.
Garrick is offline   Reply With Quote
Old 11-09-10, 04:38 PM   #2
I take it you've found your problem then?
Old 11-09-10, 05:03 PM   #3
Garrick
Garrick's Avatar
yep, No.1 cylinder shell totally balls'd. Just want to chuck a shell in by next weekend and then do a compression test as there doesn't seem to much compression in the engine either
Old 11-09-10, 05:27 PM   #4
Whys the shell destroyed? Has it damaged the crank at all?
If you just go ahead and replace it without knowing why it went, then you could easily have it happen again.... just something to be aware of.
Old 11-09-10, 05:30 PM   #5
Garrick
Garrick's Avatar
its more of a temporary meeasure until i find a replacement engine
Old 11-09-10, 05:38 PM   #6
£100 for a 1.8 dz engine that runs fine
Old 11-09-10, 06:21 PM   #7
Garrick
Garrick's Avatar
get it running next friday for me chap, concerned about the amount of oil seeping from it though!
