Classic Audi » Technical » Mech/Tech » Engine » testing a thermo switch
Old 03-08-10, 03:45 PM   #1
jack1
Default testing a thermo switch
hi,, anyone know how to go about testing a thermostat switch??
Old 03-08-10, 03:54 PM   #2
which thermostat, radiator? what car?, whats the problem?
Old 03-08-10, 04:40 PM   #3
jack1
1985 audi 90 ,rad . needle wont rise and red light fashing and water wont circulate
Old 03-08-10, 04:47 PM   #4
did you fill the rad up from the top hose or the tank ?
Old 03-08-10, 05:02 PM   #5
jack1
tried both micky and it comes through on the bottom hose
Old 03-08-10, 05:07 PM   #6
the way to test the temp gauge is to earth the wire and it should go all the way to the top .
does yours have a gauge or just the lights ?
Old 03-08-10, 05:13 PM   #7
jack1
a guage micky with a red warning light
Old 03-08-10, 05:20 PM   #8
when does the light come on ? is it straight away when you turn on the key .i am not sure about these systems weather it goes out after a wile or comes on when to hot
Old 03-08-10, 05:29 PM   #9
jack1
as soon as you turn the key so im thinking the thermo switch firstly or then maybe the pump
Old 03-08-10, 05:34 PM   #10
just unplug the switch on the rad and see if the light goes out . i am sure if you connect both wires together the fan should run permantly .
is it overheating at all .it does sound like a faulty switch tbh .
