Classic Audi » Technical » Mech/Tech » Engine » Typ85 with 7a engine? Bags of questions..
Old 01-06-10, 09:48 PM   #1
Jolfa
Default Typ85 with 7a engine? Bags of questions..
Right, I'll be hopefully getting a 90q soon, and I want to put a 7a 20v in it (can't affort a 20vt just yet).
Are the engine mounts the same between Typ89's and 85's?
Will the 85 box bolt up to a 7a?
Would I be right in thinking the 7a is essentially the same as the 6a with an extra cylinder?
What spark/fuel management do they use?
Would whatever system it uses control the spark independently if I were to go carb?
If not is there any kind of dead basic spark management off another 5 pot I can use (I'd rather not use megajolt or similar, simpler the better)?
Ta!
Jolfa is offline   Reply With Quote
Old 01-06-10, 10:05 PM   #2
ian20v
ian20v's Avatar
Cq20v on here has done it,then went 20vt in type85
Old 01-06-10, 10:14 PM   #3
Jolfa
I'll go find some threads then
One more question, Typ85 90q box on a 7a from a FWD 80/Coupe?
Old 17-07-10, 10:09 PM   #4
Jolfa
Bump, can't find anything useful on this? Anyone?
Old 17-07-10, 10:15 PM   #5
Tonks4x4
Tonks4x4's Avatar
Ta!
Engine mounts are the same.
Yes the typ 85 box will bolt to the 7a but you will need a UR WR flywheel and clutch and a spigot bearing for the back of the crank.
Not sure on the 6a question I would not think so.
I think it is hitachi
No you would need to run VEMS, 034, motec etc
Not that I can think of.
HTH
Old 17-07-10, 10:31 PM   #6
Jolfa
Brilliant, thanks!
So will the 7a engine and box mate up to the 85 prop? I can imagine sourcing quattro bits won't be easy or cheap...
What about front driveshafts? Not essential since I plan on converting to RWD until I can afford big power
Old 17-07-10, 10:49 PM   #7
And how are u going to achieve this - center diff mod with welding equipment or simply removing front driveshafts and hoping that centre diff lock will work infinitely?
Old 17-07-10, 11:00 PM   #8
Jolfa
Weld up the center diff and bin the front shafts
