Members: 19,821 | Total Threads: 40,098 | Total Posts: 471,153 Currently Active Users: 12052 (0 members and 12052 guests) Welcome to our newest member, BuddyInons |
my audi 80 has the 6x14 45et ronals with 185 60 14 tyres, if i were to go 1 up to the 7x15 42et then i can use 195 50 15 tyres, is this correct??
you should use 195/55/15 you can use 50s for a lower profile but you speedo will be out
interesting, i always thought that an inch bigger in wheel size and you decrease the profile by 10
dont forget you are also going from 185 to 195
the 50 or 55 is a percentage of the tread
so a 135 / 50 is not the same as a 155 /50 the 50 is not the same on all tyres its only a percentage so all are differant diameters just get a spare tyre take it to a fitting place and put them side by side and look at the hight differance . |
thanks micky
Black Coupe Collector
You have two options
195/55/15's or 205/50/15's I would go for 195/55/15's which is what is going on my 7jx15 ET42 Ronals ![]()
95 UrS6 87 Coupe Quattro |
theres no power steering so 195' is what il go for, yep them ronals are nice
#10 | |
185/60R14 = 578mm diameter 195/50R15 = 576mm diameter (-0.35% difference) 195/55R15 = 596mm diameter (+3.11% difference) http://www.etyres.co.uk/tyre-size-calculator.htm Don't get 55 profile, your speedo will be out, 50 profile is correct........ |
