Classic Audi » Technical » Mech/Tech » Electrical problems » radiator fan......ON......!!!
Old 30-01-10, 03:08 PM   #1
missfire
missfire's Avatar
Default radiator fan......ON......!!!
hello,........
radiator fan .....on......all the time.....??? as soon as i connect the battery....?
disconnected the temp sensor on the rad...............ON.....
has anyone had this...?? wondered if it an 'open' or 'closed' circuit problem..?
thanks
Old 30-01-10, 03:13 PM   #2
if you taken off the plug than it shouldn"t work somewhere the wires are touching each other ?
Old 30-01-10, 03:19 PM   #3
missfire
missfire's Avatar
will have a look for nasty insulation..........
could a state of 'low charge' in the battery cause any wierdness..???
new battery...not been for a decent run yet..
Old 30-01-10, 03:25 PM   #4
SteveCat
SteveCat's Avatar
Default .
Nien
Mercedes E220 Sportline Coupe
Old 30-01-10, 03:57 PM   #5
djb1607
djb1607's Avatar
This has happened to me before. It was my Multi function sensor. Its on the coolant flange coming off the motor. It also ended up almost setting the relay on fire so be careful.
djb1607 is offline   Reply With Quote
Old 30-01-10, 05:33 PM   #6
missfire
missfire's Avatar
cool .....
thought that it was the culprit in a number of other issues..........so, i will take it out and carefully............smash it to bits...!
Old 30-01-10, 05:48 PM   #7
naffa
Vorsprung durch Technik!
naffa's Avatar
This might be nonsense but couldn't it be the fan switch in the rad?
Cheers Nathan
naffa is offline   Reply With Quote
Old 30-01-10, 06:08 PM   #8
missfire
missfire's Avatar
yup...this is what i meant by my first post....
on an audi 100.....
does the switch close to turn the fan on...?
or
does the switch open to turn the fan on...?
because i disconnected it, and the fan was still running..............
Old 01-02-10, 10:58 PM   #9
Woodsman
Missfire, does the fan relay click when you connect the battery?
Does it still run if the relay is removed?
If no to both then most likely the relay contacts welded together.
If the relay does click then something is triggering it, MFTS, Fan after run relay, radiator switch, wiring short, etc.............
If it does still run with the relay removed then the motor feed is shorted to B+.
If the fan has more than one speed, then each speed will probably have a separate relay, Which speed is the fan running at when it shouldn't be?
I'm quite sure that most fan switches will be normally open (ie closed = fan on)
Woodsman is offline   Reply With Quote
Old 01-02-10, 11:43 PM   #10
missfire
missfire's Avatar
Woodsman
i will check out the relay...pretty sure it is a single speed system but will make sure..!
it does not seem to be running very fast.....so if it is a 2 or 3 speed system, it is running on the 'lowest speed' setting,....all the time...!
weirdest thing was....i was out and fitted a new heater resistor pack into the blower motor housing.......no drama...(blower still does not work !! blower motor works with a direct feed, so the controls must be nackered.....) then went indoors for about an hour..
then let the dog out for a sniff around .........and the fan was running ...
and now it wont go off... so watever happened...it did so without the ignition switch on....
anyway...i will go for a snoop one day with a multi-meter....thanks
type 85 radiator john johnson Parts For Sale 0 30-08-09 07:22 AM
kv radiator slacky Parts Wanted 4 31-07-09 08:35 PM
10v Radiator question djb1607 Engine 7 31-07-09 05:31 PM
Radiator, will this one fit? Scarlet Engine 2 07-05-09 06:25 PM
New Radiator poopcoupe Parts Wanted 28 16-01-09 05:28 PM
