Classic Audi » Technical » Mech/Tech » Engine » spark plug gaps/ tolerances
Old 20-01-10, 01:44 PM   #1
Default spark plug gaps/ tolerances
in the box of new spark plugs there are 2 very thin washers.
how do I measure the tolerance gap or do i just stick them in with the 2 washers in
cheers
Old 20-01-10, 02:07 PM   #2
are you on about the crush washers that fit around the threads of the plug
Old 20-01-10, 02:09 PM   #3
Martc
Black Coupe Collector
Martc's Avatar
I think he is on about the crush washers - should only need 1 per plug
Are the plugs 3 electrode? If so should not need setting, should have the gap printed somewhere on the box
95 UrS6
87 Coupe Quattro
Old 20-01-10, 02:50 PM   #4
No idear what the gap is on this ??
Old 20-01-10, 02:53 PM   #5
imperial or metric
I'd say a good 8 inches will do
give or take half a thou
ok... the spark plugs supplied to me are NGK 1263 BP6ET' s
yes it has 3 prongs and ..............OH its only 1 crush washer then!! It has a faint line around it and first glance looked as if it was 2 !!
Old 20-01-10, 02:53 PM   #6
i can see that one a bit better, may need both washers though
Old 20-01-10, 03:03 PM   #7
looks like Kate Winslet to me
Old 20-01-10, 03:10 PM   #8
Martc
Martc's Avatar
Looks like the KLA strikes again...
Keely Liberation Army....
95 UrS6
87 Coupe Quattro
Old 20-01-10, 03:15 PM   #9
did you see Life On Mars?
choice of Bolly Knickers or Annie....
feel a poll coming on
Old 20-01-10, 03:16 PM   #10
Leave you poll alone you perv
Core plug sizes Budgie Technical Info 5 20-08-09 08:57 AM
wrong KV spark plugs? Gaz Engine 9 06-07-09 12:11 PM
dizzy cap and spark leads tommyboy Parts Wanted 8 28-06-09 12:08 PM
Core Plug Set - B2 five pot BigT80 Technical Info 5 06-03-09 11:40 AM
spark plugs 100turbo c Engine 1 14-12-08 09:33 PM
