Members: 19,727 | Total Threads: 40,088 | Total Posts: 471,062 Currently Active Users: 4562 (1 members and 4561 guests) Welcome to our newest member, Esmeraldosojf |
as per title,
anyone happen to have a sunroof panel for a type 85 80/90. Ideally with mech but id take one without. Just to add the coupe ones are different and wont fit Thanks Gav |
If you're not fussed about tilt and slide, Mk2 Golf ones should fit.
I sold my sunroof to a Mk2 Golf boy as the Audi 80 ones tilt and slide, but the Mk2 Golf ones only tilt........ |
Other way round isn't it ?
My Mark 2 Golfs both had sunroofs and they both slid open but didnt tilt
you're right, I was confused!
But the panel should be the same??? |
aye theyre the same size but not sure if theyre interchangable between the mk2 and audi mechs
cheers Gav |
Corrado....
sod that, ive had 12 corrados and ive had to fix the bloody sunroof on every single one. 11 of them ive fitted passat estate panel and mechs too as theyre a straight swap.
Do corrado mechs.panels bolt straight up to the 80/90? id beinterested if they did as i can then convert mine to electic sunroof Thanks, you given me an idea now Gav |
The original sin
passat one's should be an easy find and could get a glass one.
80 tdi avant |
B2 80/90 fit into Mk2 with the mechanism, so if you get a Mk2 Golf one, with the mechanism, it should fit your B2..........
Lets put it this way, the seal is the same part, my brothers 86GT has a Corrado seal, just reversed on fitment, inside is outside, if you get my drift.
| Type 85 sunroof seal | ian20v | Parts Wanted | 8 | 04-02-10 06:55 PM |
| Audi 80 sport type 81, Door strip panel | type81 | Parts Wanted | 1 | 12-12-09 06:09 PM |
| t85 sunroof panel | peanut | Bodywork, glass & exterior fitments | 3 | 05-12-09 09:01 PM |
| Sunroof panel and mechanism. | 4v6 | Parts Wanted | 0 | 27-06-09 06:30 PM |
| Sunroof Seal | 86audicoupe | General Chat | 4 | 10-03-08 07:40 PM |
