Classic Audi » Classifieds section » Parts Wanted » 1982 Quad headlight Trims - Urgently Wanted!
Old 03-08-07, 09:20 PM   #1
krzracingcouk
krzracingcouk's Avatar
Red face 1982 Quad headlight Trims - Urgently Wanted!
Hi All,
This is something I have been after for a very long time now to restore my lovely 1982 Audi Coupe GT 5S.
I am after the headlight trims for the quad headlight version, so I can put back in the Mark 1 headlights and remove the modern twin headlights that I have put in.
I have good money waiting for these and I do not mind what condition as I can rebuild, just unfortunately I do not have the ones from my car as the bits got lost in the move and as a result can not rebuild.
Also I am after a replacement oil pressure sensor that is at the front bottom of the engine as mine has started to leak.
I would much appricate any help on getting this lovely car back to it's glory.
Till then keep it Audi.
krzracingcouk is offline   Reply With Quote
Old 03-08-07, 10:12 PM   #2
The best place to find quad lamp Bezels are on the German Ebay, but sadly they ar fetching silly money at the mo anywhere from 80 -120 euros
Old 04-08-07, 02:41 PM   #3
krzracingcouk
Cool Thank you I will give it a go
Hi Nigel,
Thank you for your help. I will give it a go.
As for money I do not mind paying that at all, I just want the car to have the mark one headlights back in.
Thanks again and once I have them in I will get pictures up on this site.
Old 04-08-07, 04:16 PM   #4
No problem mate, I had to get mine from the Fatherland for my quattro as I needed only the outer part of the Bezels as the "group 4" rally quattros only use the H4 headlight.
http://cgi.ebay.de/Doppelscheinwerfe...QQcmdZViewItem
I managed also to get from Hella the H4 lamps, these are NLA from Audi, but if you can get a local motor factor who deal direct with Hella UK in Banbury you can still get them, part number 1LB003177-511
Hope thats of help
Nigel
Old 06-08-07, 04:10 PM   #5
krzracingcouk
Cool Thank you again for your help
Hi Nigel,
I found the one you have also linked to, he only has the one side and it is the other side I really need. Mind you a spare is always a good thing.
I will also try my local motor factors with that code you have given me, I can not wait to get my car back to the original look front end.
Till then, keep it Audi all the way...
7A distributor wanted urgently! Coxy Parts Wanted 6 20-05-09 04:02 PM
s6 aan alternatorr urgently needed peanut Parts Wanted 7 17-03-09 09:31 PM
Walnut dash and door trims wanted SteveCat Parts Wanted 0 24-02-08 09:07 PM
