Members: 19,714 | Total Threads: 40,088 | Total Posts: 471,059 Currently Active Users: 1164 (2 members and 1162 guests) Welcome to our newest member, Oliveagax |
Mr Typ 43!
This is a classic Audi problem. My 200 5E starts fine apart from for half an hour after its warmed up. It refuses to start and then suddenly when the temp drops to a certain level is fine again. My two suspects are the warm up regulator and the auxillary air valve - both have bi-metallic strips. I also have a slight problem where the revs go up instead of down when the engine warms up - I suspect the two things are related. What should I replace first - the fuel enrichment device or the air enrichment device? or could it be something else... (btw it's not the CSV).
I had the same prob on my 200q, eventually changed the injectors[last] symptoms improved , they are as i am sure you know notorius for poor hot start
, you could also check the injector fan switch,,this blows cold air on to the injectors, lastly and most expensive ,weak fuel pump , relatively easy to check[in line guage should do it] although the pumps i had probs with were all fairly noisey as they got more tired, best of luck, liked the resto pics chris |
Mr Typ 43!
Thanks for the advice. The injectors are new and so is the pump -a weak pump is a possibility as the pump was not genuine??? The air valve is okay I think and I can't see that the warm up regulator would stop it starting all together. What about the thermotime switch??? Thanks, I know this is a boring subject!
Mr Typ 43!
I have found the problem - the thermotime switch is only delivering 4.5V. Anyone know if I can get a replacement from Audi? Would this cause a problem with warm starting?
| 1995 Audi Coupe wont cold start!!!!!!!! | aheath55499 | Engine | 2 | 08-10-09 09:35 PM |
| Audi 100 Typ 44 jump start terminals? | pimpdriver | Electrical problems | 10 | 11-02-09 08:28 PM |
| why won't it start? | aeinstein | Engine | 4 | 28-01-09 10:05 PM |
| audi 90 poor cold start...... | johnboy | Engine | 14 | 25-09-08 05:43 PM |
